Hi, got this error when executing telegram bot on asus tinkerboard after uploading it with balena cli.
This bot works perfectly outside, everything is at the latest version.
Can’t figure out why it’s giving me this error on “compact.js”.
Did every type of reset.
Node version 14.17.3
Any help is appreciated
<main> > vmh_bot@1.0.0 start /usr/src/app
<main> > node vmh_bot.js
<main>
<main> /usr/src/app/node_modules/telegraf/lib/core/helpers/compact.js:11
<main> return Object.fromEntries(compactEntries);
<main> ^
<main>
<main> TypeError: Object.fromEntries is not a function
<main> at Object.compactOptions (/usr/src/app/node_modules/telegraf/lib/core/helpers/compact.js:11:19)
<main> at new ApiClient (/usr/src/app/node_modules/telegraf/lib/core/network/client.js:208:26)
<main> at new Telegram (/usr/src/app/node_modules/telegraf/lib/telegram.js:7:1)
<main> at new Telegraf (/usr/src/app/node_modules/telegraf/lib/telegraf.js:45:25)
<main> at Object.<anonymous> (/usr/src/app/vmh_bot.js:4:13)
<main> at Module._compile (internal/modules/cjs/loader.js:689:30)
<main> at Object.Module._extensions..js (internal/modules/cjs/loader.js:700:10)
<main> at Module.load (internal/modules/cjs/loader.js:599:32)
<main> at tryModuleLoad (internal/modules/cjs/loader.js:538:12)
<main> at Function.Module._load (internal/modules/cjs/loader.js:530:3)
<main> npm ERR! code ELIFECYCLE
<main> npm ERR! errno 1
<main> npm ERR! vmh_bot@1.0.0 start: `node vmh_bot.js`
<main> npm ERR! Exit status 1
<main> npm ERR!
<main> npm ERR! Failed at the vmh_bot@1.0.0 start script.
<main> npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
<main>
<main> npm ERR! A complete log of this run can be found in:
<main> npm ERR! /root/.npm/_logs/2021-07-15T16_13_23_401Z-debug.log
Service exited 'main sha256:f558421c653fa5eab4a49b62c5e02c5fc04dbe2e020eab97a597afbc940dd79d'
