Here is the log dump from console.
“name”: “Error”,
“message”: “The module ‘/tmp/pkg/7a4c5bad9a3743a3b0f01425ecde6ebfab4e53f2e7edd3aaccbf43c4d0719a0d/mountutils/build/Release/MountUtils.node’\nwas compiled against a different Node.js version using\nNODE_MODULE_VERSION 93. This version of Node.js requires\nNODE_MODULE_VERSION 108. Please try re-compiling or re-installing\nthe module (for instance, using npm rebuild or npm install).”,
“stack”: “Error: The module ‘/tmp/pkg/7a4c5bad9a3743a3b0f01425ecde6ebfab4e53f2e7edd3aaccbf43c4d0719a0d/mountutils/build/Release/MountUtils.node’\nwas compiled against a different Node.js version using\nNODE_MODULE_VERSION 93. This version of Node.js requires\nNODE_MODULE_VERSION 108. Please try re-compiling or re-installing\nthe module (for instance, using npm rebuild or npm install).\n at process.dlopen (pkg/prelude/bootstrap.js:2251:28)\n at Module._extensions…node (node:internal/modules/cjs/loader:1196:18)\n at Module.load (node:internal/modules/cjs/loader:988:32)\n at Module._load (node:internal/modules/cjs/loader:834:12)\n at Module.require (node:internal/modules/cjs/loader:1012:19)\n at Module.require (pkg/prelude/bootstrap.js:1851:31)\n at require (node:internal/modules/cjs/helpers:102:18)\n at bindings (/snapshot/home/runner/work/etcher/etcher/node_modules/bindings/bindings.js:112:48)\n at Object. (/snapshot/home/runner/work/etcher/etcher/node_modules/mountutils/index.js:52:37)\n at Module._compile (pkg/prelude/bootstrap.js:1926:22)”,
“code”: “ERR_DLOPEN_FAILED”
Terminating IPC server
gui.js:3 Error: The writer process ended unexpectedly
at createError (gui.js:3:225919)
at Object.createUserError (gui.js:3:226132)
at finish (gui.js:307:2613)
at Server.onFail (gui.js:307:2100)
at Server.emit (gui.js:3:445008)
at Server.gotData (gui.js:3:450365)
at Socket.emit (node:events:513:28)
at addChunk (node:internal/streams/readable:324:12)
at readableAddChunk (node:internal/streams/readable:293:11)
at Readable.push (node:internal/streams/readable:234:10)
at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
gui.js:3 Error: Error invoking remote method ‘enable-screensaver’: Error: No handler registered for ‘enable-screensaver’
at a.invoke (node:electron/js2c/renderer_init:2:7723)
