Problems with Etcher 1.5.74 Windows 10 and Windows 8.1
In windows 8.1 and 10 executed as administrator. Even portable or setup.
Getting the same problem on macOS 10.15.3. Console output:
    `{"stack":"TypeError: Cannot convert undefined or null to object\n    at Function.entries (<anonymous>)\n    at Object.init (file:///Applications/balenaEtcher.app/Contents/Resources/app/generated/gui.js:3951:49)\n    at main (file:///Applications/balenaEtcher.app/Contents/Resources/app/generated/gui.js:3633:12)","message":"Cannot convert undefined or null to object"}`
Same issue here on build 19041.21
Hi, we confirm that there’s a problem with 1.5.74. We are working to fix it. Meanwhile, can you use previous version? https://github.com/balena-io/etcher/releases/tag/v1.5.73 . Sorry for inconvenience.
Hi, the fix is now released in v1.5.75.
Zahari
