Windows7 fail to flash Micro SD card
Windows7 Pro
BalenaEtcher ver 1.5.101
When a try to flash any MicroSd card, I see error:
Balena-etcher.pdf (65.4 KB).
I’ve tryed both portable and installed versions.
The log file is:
LOG.pdf (227.4
Etcher ver. 1.4.4 on the same computer in the same time works fine.
Thanks for reporting the issue!
We’ll take a look and get back to you once we figure out the problem.
Hi again,
Can you try with a different image, a smaller one possibly, and report back the logs again in case it fails?
