hello and thanks,
each time i run etcher, it fails to image the sdcard.
and all i get is generic pop-up message.
no error number, no log file
thanks much,
david
hello and thanks,
thanks much,
david
Welcome to forums!
In order to help us get to the root of the problem, will you please send us the following information:
Thank you, and kind regards
Alida
Also, @asdffdsa6131, can you please share what you see when accessing the console logs? You can access these by pressing Ctrl+Shift+i (or Cmd+Alt+i if you’re on Mac OS). Thanks!
thanks,
On which operating system are you running balenaEtcher?
win.10.2004.64
Which version of balenaEtcher are you using?
balenaEtcher-Portable-1.5.101.exe
Do you get the same error when trying to write the image to different sd cards?
yes, all three sdcards i have tried, two are brand new. windows can read the sdcard, format the sdcard, copy files to the sdcard. computer management has no problem with the sdcard.
Do you get the same error if you try to write a different image to the sd card, or is it only failing for a particular image?
yes for any image and iso that i try.
thanks
gui.js:82328 _____ _ _
| | | | | | ___ _ __
| || / | ’ \ / _ \ '|
_/ ____|| ||___||
Interested in joining the Etcher team?
Drop us a line at join+etcher@balena.io
Version = 1.5.101, Type = portable
gui.js:132997 Wed Jul 15 2020 15:15:42 GMT-0400 (Eastern Daylight Time) Application start ({“packageType”:“portable”,“version”:“1.5.101”,“sample”:0.1,“applicationSessionUuid”:“7d2cf7cb-746c-43b3-91dd-a3671bb7be7a”,“flashingWorkflowUuid”:“ff15a48b-adbb-4a08-9629-c283ea1f48fc”})
gui.js:125699 Wed Jul 15 2020 15:15:45 GMT-0400 (Eastern Daylight Time) Open image selector ({“sample”:0.1,“applicationSessionUuid”:“7d2cf7cb-746c-43b3-91dd-a3671bb7be7a”,“flashingWorkflowUuid”:“ff15a48b-adbb-4a08-9629-c283ea1f48fc”})
gui.js:125699 Wed Jul 15 2020 15:15:48 GMT-0400 (Eastern Daylight Time) Image selector closed ({“sample”:0.1,“applicationSessionUuid”:“7d2cf7cb-746c-43b3-91dd-a3671bb7be7a”,“flashingWorkflowUuid”:“ff15a48b-adbb-4a08-9629-c283ea1f48fc”})
gui.js:125699 Wed Jul 15 2020 15:15:54 GMT-0400 (Eastern Daylight Time) Open image selector ({“sample”:0.1,“applicationSessionUuid”:“7d2cf7cb-746c-43b3-91dd-a3671bb7be7a”,“flashingWorkflowUuid”:“ff15a48b-adbb-4a08-9629-c283ea1f48fc”})
gui.js:125699 Wed Jul 15 2020 15:15:55 GMT-0400 (Eastern Daylight Time) Select image ({“image”:{“size”:1853882368,“name”:“2020-05-27-raspios-buster-lite-armhf.img”,“hasMBR”:true,“partitions”:[{“offset”:4194304,“size”:268435456,“type”:12,“index”:1},{“offset”:272629760,“size”:1581252608,“type”:131,“index”:2}],“path”:“C:\data\l\pi\2020-05-27-raspios-buster-lite-armhf\2020-05-27-raspios-buster-lite-armhf.img”,“extension”:“img”,“logo”:false,“blockMap”:false},“sample”:0.1,“applicationSessionUuid”:“7d2cf7cb-746c-43b3-91dd-a3671bb7be7a”,“flashingWorkflowUuid”:“ff15a48b-adbb-4a08-9629-c283ea1f48fc”})
gui.js:125699 Wed Jul 15 2020 15:15:59 GMT-0400 (Eastern Daylight Time) Toggle drive ({“drive”:{“size”:31247564800,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“SDHC Card”,“isUAS”:false},“previouslySelected”:false,“sample”:0.1,“applicationSessionUuid”:“7d2cf7cb-746c-43b3-91dd-a3671bb7be7a”,“flashingWorkflowUuid”:“ff15a48b-adbb-4a08-9629-c283ea1f48fc”})
gui.js:125699 Wed Jul 15 2020 15:16:01 GMT-0400 (Eastern Daylight Time) Flash ({“image”:“C:\data\l\pi\2020-05-27-raspios-buster-lite-armhf\2020-05-27-raspios-buster-lite-armhf.img”,“drives”:[{“size”:31247564800,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“SDHC Card”,“isUAS”:false}],“driveCount”:1,“uuid”:“1b7c99ba-5598-4efd-989c-7dbbe1ff65db”,“status”:“started”,“flashInstanceUuid”:“1b7c99ba-5598-4efd-989c-7dbbe1ff65db”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“sample”:0.1,“applicationSessionUuid”:“7d2cf7cb-746c-43b3-91dd-a3671bb7be7a”,“flashingWorkflowUuid”:“ff15a48b-adbb-4a08-9629-c283ea1f48fc”})
gui.js:125699 Elevating command: C:\data\l\pi\1eS4mlRBEowgJodugL6Y7Ada4H4\balenaEtcher.exe C:\data\l\pi\1eS4mlRBEowgJodugL6Y7Ada4H4\resources\app
gui.js:125699 Successfully connected to IPC server: etcher-server-6728, socket root C:\Users\user01\AppData\Local\Temp
gui.js:125699 Image: C:\data\l\pi\2020-05-27-raspios-buster-lite-armhf\2020-05-27-raspios-buster-lite-armhf.img
gui.js:125699 Devices: \.\PhysicalDrive1
gui.js:125699 Umount on success: true
gui.js:125699 Validate on success: true
gui.js:125699 Auto blockmapping: true
gui.js:125699 Decompress first: true
gui.js:7847 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:125699 Wed Jul 15 2020 15:16:02 GMT-0400 (Eastern Daylight Time) SafeWebview loaded ({“event”:{“id”:1,“url”:“https://assets.balena.io/etcher-featured/index.html?borderRight=false&darkBackground=true&etcher-version=1.5.101&api-version=2&optOutAnalytics=true",“method”:“GET”,“timestamp”:1594840562694.341,“resourceType”:“mainFrame”,“ip”:“104.31.82.157”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“access-control-allow-origin”:["*"],“age”:[“0”],“cache-control”:[“max-age=600”],“cf-cache-status”:[“DYNAMIC”],“cf-ray”:[“5b35d0cceddbf060-EWR”],“cf-request-id”:[“03f580d4130000f0609fac1200000001”],“content-encoding”:[“br”],“content-type”:[“text/html; charset=utf-8”],“date”:[“Wed, 15 Jul 2020 19:16:02 GMT”],“expect-ct”:[“max-age=604800, report-uri=“https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct””],“expires”:[“Wed, 15 Jul 2020 14:15:35 GMT”],“last-modified”:[“Wed, 17 Jun 2020 21:19:41 GMT”],“server”:[“cloudflare”],“status”:[“200”],“vary”:[“Accept-Encoding”],“via”:[“1.1 varnish”],“x-cache”:[“HIT”],“x-cache-hits”:[“1”],“x-fastly-request-id”:[“8c75679cc68d686712279e3ec0e1fdb958a02e08”],“x-github-request-id”:[“B752:340F:18D79D:1E79B2:5F0F0D2E”],“x-origin-cache”:[“HIT”],“x-proxy-cache”:[“MISS”],“x-served-by”:[“cache-ewr18156-EWR”],“x-timer”:[“S1594840563.722818,VS0,VE42”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“7d2cf7cb-746c-43b3-91dd-a3671bb7be7a”,“flashingWorkflowUuid”:“ff15a48b-adbb-4a08-9629-c283ea1f48fc”})
gui.js:125699 Wed Jul 15 2020 15:16:07 GMT-0400 (Eastern Daylight Time) Flash error ({“image”:“C:\data\l\pi\2020-05-27-raspios-buster-lite-armhf\2020-05-27-raspios-buster-lite-armhf.img”,“drives”:[{“size”:31247564800,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“SDHC Card”,“isUAS”:false}],“driveCount”:1,“uuid”:“1b7c99ba-5598-4efd-989c-7dbbe1ff65db”,“flashInstanceUuid”:“1b7c99ba-5598-4efd-989c-7dbbe1ff65db”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“error”:{“name”:“Error”,“message”:“EPERM: operation not permitted, write”,“stack”:“Error: EPERM: operation not permitted, write”,“code”:“EPERM”,“syscall”:“write”,“errno”:-4048},“sample”:0.1,“applicationSessionUuid”:“7d2cf7cb-746c-43b3-91dd-a3671bb7be7a”,“flashingWorkflowUuid”:“ff15a48b-adbb-4a08-9629-c283ea1f48fc”})
gui.js:125699 Finish: 0
gui.js:125699 Terminating IPC server
gui.js:125699 Flash results Object
gui.js:125699 Wed Jul 15 2020 15:16:10 GMT-0400 (Eastern Daylight Time) Write failed ({“image”:“C:\data\l\pi\2020-05-27-raspios-buster-lite-armhf\2020-05-27-raspios-buster-lite-armhf.img”,“drives”:[{“size”:31247564800,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“SDHC Card”,“isUAS”:false}],“driveCount”:1,“uuid”:“1b7c99ba-5598-4efd-989c-7dbbe1ff65db”,“status”:“failed”,“flashInstanceUuid”:“1b7c99ba-5598-4efd-989c-7dbbe1ff65db”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“error”:{“description”:“Please try again, and contact the Etcher team if the problem persists”,“report”:false,“code”:“ECHILDDIED”},“sample”:0.1,“applicationSessionUuid”:“7d2cf7cb-746c-43b3-91dd-a3671bb7be7a”,“flashingWorkflowUuid”:“ff15a48b-adbb-4a08-9629-c283ea1f48fc”})
so this is not just an etcher problem.
i have tried a few other tools and they all fail.
Hi @asdffdsa6131 – thanks for the additional info. I just want to clarify one point to make sure I understand correctly: at the end of your message, you say “so this is not just an etcher problem. i have tried a few other tools and they all fail.” Can you confirm:
Can you please confirm whether I got all that right?
Assuming for the moment that I do: can you try a couple of workarounds and see if they work for you?
Thanks, and please let us know how it goes.
All the best,
Hugh
thanks @AlidaOdendaal
thanks @saintaardvark
working now by tweaking allow an app through controler folder access
never had such a problem before with win10.
been using yumi, rufus and so many tools for many years.
just now, when i tried to use yumi, i got an error message, could not change boot record.
so that might be the exact issue, that windows now considers boot sectors are system protected.
i recently updated to win10.2004,
perhaps that update tightened the security, more than in the past
and i checked the list of protected folders and usb and sd cards drives are not listed.
but states that windows system folders are protected by default.
but i found this in the list of block history
Hi @asdffdsa6131 – glad to hear this has resolved your problems! Thanks again for lettingus know about this.
All the best,
Hugh
I get the same error immediately and at 100% on older Sony Viao laptop running windows 10.
Tried several OSs for my Raspberry pi 4
The only success was the Raspian imager loading Raspian OS.
hello,
so you tried all the suggestions in this post and none of them worked?
i am runnning ubuntu on my my pi4, runs great and it is 64bit, not 32bit.
