Dear Ones,
Kindly help me out, I am using the latest balenaEtcher which is 1.5.105
something went wrong. if it is a compressed image, please check that the archive is not corrupted.
gui.js:79504 _____ _ _
| | | | | | ___ _ __
| || / | ’ \ / _ \ '|
_/ ____|| ||___||
Interested in joining the Etcher team?
Drop us a line at join+etcher@balena.io
Version = 1.5.105, Type = nsis
gui.js:56114 Sun Nov 22 2020 16:23:06 GMT+0530 (India Standard Time) Application start ({“packageType”:“nsis”,“version”:“1.5.105”,“sample”:0.1,“applicationSessionUuid”:“5581cad6-8487-453f-81b1-5cb1472db82e”,“flashingWorkflowUuid”:“8e717b2a-3f56-4f92-a686-c9e86019dbcb”})
gui.js:56184 {“stack”:“Error: The specified module could not be found.\r\n\\?\C:\Users\MB YUVARAJ\AppData\Local\Programs\balena-etcher\resources\app\generated\modules\winusb-driver-generator\build\Release\Generator.node\n at process.func [as dlopen] (electron/js2c/asar.js:140:31)\n at Object.Module._extensions…node (internal/modules/cjs/loader.js:1034:18)\n at Object.func [as .node] (electron/js2c/asar.js:140:31)\n at Module.load (internal/modules/cjs/loader.js:815:32)\n at Module._load (internal/modules/cjs/loader.js:727:14)\n at Function.Module._load (electron/js2c/asar.js:769:28)\n at Module.require (internal/modules/cjs/loader.js:852:19)\n at require (internal/modules/cjs/helpers.js:74:18)\n at Object. (file:///C:/Users/MB%20YUVARAJ/AppData/Local/Programs/balena-etcher/resources/app/generated/gui.js:36644:22)\n at webpack_require (file:///C:/Users/MB%20YUVARAJ/AppData/Local/Programs/balena-etcher/resources/app/generated/gui.js:16:27)”,“message”:“The specified module could not be found.\r\n\\?\C:\Users\MB YUVARAJ\AppData\Local\Programs\balena-etcher\resources\app\generated\modules\winusb-driver-generator\build\Release\Generator.node”}
logException @ gui.js:56184
gui.js:48816 Sun Nov 22 2020 16:23:09 GMT+0530 (India Standard Time) Open image selector ({“sample”:0.1,“applicationSessionUuid”:“5581cad6-8487-453f-81b1-5cb1472db82e”,“flashingWorkflowUuid”:“8e717b2a-3f56-4f92-a686-c9e86019dbcb”})
gui.js:48816 Sun Nov 22 2020 16:23:13 GMT+0530 (India Standard Time) Select image ({“image”:{“size”:1431306240,“name”:“linux-lite-5.2-64bit.iso”,“hasMBR”:true,“partitions”:[{“offset”:169984,“size”:3833856,“type”:239,“index”:1}],“path”:“D:\BalenaEtcher\linux-lite-5.2-64bit.iso”,“extension”:“iso”,“logo”:false,“blockMap”:false},“sample”:0.1,“applicationSessionUuid”:“5581cad6-8487-453f-81b1-5cb1472db82e”,“flashingWorkflowUuid”:“8e717b2a-3f56-4f92-a686-c9e86019dbcb”})
gui.js:48816 Sun Nov 22 2020 16:23:17 GMT+0530 (India Standard Time) Toggle drive ({“drive”:{“size”:7948206080,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“G:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“G:\”}],“description”:“Mass Storage Device USB Device”,“isUAS”:false},“previouslySelected”:false,“sample”:0.1,“applicationSessionUuid”:“5581cad6-8487-453f-81b1-5cb1472db82e”,“flashingWorkflowUuid”:“8e717b2a-3f56-4f92-a686-c9e86019dbcb”})
gui.js:48816 Sun Nov 22 2020 16:23:18 GMT+0530 (India Standard Time) Flash ({“image”:“D:\BalenaEtcher\linux-lite-5.2-64bit.iso”,“drives”:[{“size”:7948206080,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“G:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“G:\”}],“description”:“Mass Storage Device USB Device”,“isUAS”:false}],“driveCount”:1,“uuid”:“f93a4e8b-8fe4-464d-9073-1f3c75438653”,“status”:“started”,“flashInstanceUuid”:“f93a4e8b-8fe4-464d-9073-1f3c75438653”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“sample”:0.1,“applicationSessionUuid”:“5581cad6-8487-453f-81b1-5cb1472db82e”,“flashingWorkflowUuid”:“8e717b2a-3f56-4f92-a686-c9e86019dbcb”})
gui.js:48816 Elevating command: C:\Users\MB YUVARAJ\AppData\Local\Programs\balena-etcher\balenaEtcher.exe C:\Users\MB YUVARAJ\AppData\Local\Programs\balena-etcher\resources\app\generated\child-writer.js
gui.js:5626 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:48816 Successfully connected to IPC server: etcher-server-6020, socket root C:\Users\MBYUVA~1\AppData\Local\Temp
gui.js:48816 Image: D:\BalenaEtcher\linux-lite-5.2-64bit.iso
gui.js:48816 Devices: \.\PhysicalDrive1
gui.js:48816 Umount on success: true
gui.js:48816 Validate on success: true
gui.js:48816 Auto blockmapping: true
gui.js:48816 Decompress first: true
gui.js:48816 Terminating IPC server
gui.js:48816 Flash results Object
gui.js:48816 Sun Nov 22 2020 16:23:21 GMT+0530 (India Standard Time) Write failed ({“image”:“D:\BalenaEtcher\linux-lite-5.2-64bit.iso”,“drives”:[{“size”:7948206080,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“G:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“G:\”}],“description”:“Mass Storage Device USB Device”,“isUAS”:false}],“driveCount”:1,“uuid”:“f93a4e8b-8fe4-464d-9073-1f3c75438653”,“status”:“failed”,“flashInstanceUuid”:“f93a4e8b-8fe4-464d-9073-1f3c75438653”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“error”:{“killed”:false,“code”:3221225477,“signal”:null,“cmd”:“C:\Users\MB YUVARAJ\AppData\Local\Programs\balena-etcher\balenaEtcher.exe MB YUVARAJ\AppData\Local\Programs\balena-etcher\resources\app\generated\child-writer.js”,“stdout”:"",“stderr”:""},“sample”:0.1,“applicationSessionUuid”:“5581cad6-8487-453f-81b1-5cb1472db82e”,“flashingWorkflowUuid”:“8e717b2a-3f56-4f92-a686-c9e86019dbcb”})
gui.js:48816 {“stack”:“Error: Command failed: C:\Users\MB YUVARAJ\AppData\Local\Programs\balena-etcher\balenaEtcher.exe C:\Users\MB YUVARAJ\AppData\Local\Programs\balena-etcher\resources\app\generated\child-writer.js\n\n at ChildProcess.exithandler (child_process.js:304:12)\n at ChildProcess.emit (events.js:223:5)\n at maybeClose (internal/child_process.js:1021:16)\n at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)”,“message”:“Command failed: C:\Users\MB YUVARAJ\AppData\Local\Programs\balena-etcher\balenaEtcher.exe C:\Users\MB YUVARAJ\AppData\Local\Programs\balena-etcher\resources\app\generated\child-writer.js\n”,“killed”:false,“code”:3221225477,“signal”:null,“cmd”:“child-writer.js”,“stdout”:"",“stderr”:"",“image”:“linux-lite-5.2-64bit.iso”}
console. @ gui.js:48816
