"User did not grant permission" when running as Admin on Windows 7
I have been attempting to use Balena to program an SD card with a firmware image for one of my employer’s products; we normally use Roadkil’s Disk Imager but we are currently looking at alternatives. Although I have been able to program a similar firmware image in the past on a Windows 10 system when working from home, I am currently receiving Something went wrong. It it is a compressed image, please check that the archive is not corrupted. User did not grant permission on the Windows 7 desktop in the lab.
I have tried running the standalone build as Administrator and I have also tried running command prompt as Administrator, executing the standalone programmer from the command line. Here is a dump from the console:
index.css:1 Failed to load resource: net::ERR_FILE_NOT_FOUND
electron/js2c/renderer_init.js:13 (electron) The remote module is deprecated. Use GitHub - electron/remote: Bridge JavaScript objects from the main process to the renderer process in Electron. instead.
log @ electron/js2c/renderer_init.js:13
gui.js:364 _____ _ _
| | ___ _ __
| || / | ’ \ / _ \ '|
_
/ ____|| ||___||
Interested in joining the Etcher team?
Drop us a line at join+etcher@balena.io
Version = 1.7.8, Type = portable
gui.js:46 Mon Mar 28 2022 09:31:45 GMT+0100 (British Summer Time) Application start ({“packageType”:“portable”,“version”:“1.7.8”,“sample”:0.1,“applicationSessionUuid”:“4a733433-4f14-45fa-9afb-29f55f0ba235”,“flashingWorkflowUuid”:“36055f9a-ef58-4ca5-863b-17054ea8a71e”})
gui.js:46 {“stack”:“Error: The specified module could not be found.\r\n\\?\C:\Users\Admin\AppData\Local\Temp\26ZDwweoEftoYLfXXExMqtMd7tA\resources\app\generated\modules\winusb-driver-generator\build\Release\Generator.node\n at process.func [as dlopen] (electron/js2c/asar_bundle.js:5:1846)\n at Object.Module._extensions…node (internal/modules/cjs/loader.js:1138:18)\n at Object.func [as .node] (electron/js2c/asar_bundle.js:5:1846)\n at Module.load (internal/modules/cjs/loader.js:935:32)\n at Module._load (internal/modules/cjs/loader.js:776:14)\n at Function.f.load (electron/js2c/asar_bundle.js:5:12913)\n at Function.o.load (electron/js2c/renderer_init.js:33:379)\n at Module.require (internal/modules/cjs/loader.js:959:19)\n at require (internal/modules/cjs/helpers.js:88:18)\n at Object.defineProperty.value (file:///C%3A/Users/Admin/AppData/Local/Temp/26ZDwweoEftoYLfXXExMqtMd7tA/resources/app/generated/gui.js:35:145014)“,“message”:“The specified module could not be found.\r\n\\?\C:\Users\Admin\AppData\Local\Temp\26ZDwweoEftoYLfXXExMqtMd7tA\resources\app\generated\modules\winusb-driver-generator\build\Release\Generator.node”}
logException @ gui.js:46
gui.js:46 [Axios v1.7.8] Transitional option ‘clarifyTimeoutError’ has been deprecated since v1.0.0 and will be removed in the near future
console. @ gui.js:46
gui.js:46 [Axios v1.7.8] Transitional option ‘forcedJSONParsing’ has been deprecated since v1.0.0 and will be removed in the near future
gui.js:46 [Axios v1.7.8] Transitional option ‘silentJSONParsing’ has been deprecated since v1.0.0 and will be removed in the near future
gui.js:46 Mon Mar 28 2022 09:31:46 GMT+0100 (British Summer Time) Open image selector ({“sample”:0.1,“applicationSessionUuid”:“4a733433-4f14-45fa-9afb-29f55f0ba235”,“flashingWorkflowUuid”:“36055f9a-ef58-4ca5-863b-17054ea8a71e”})
gui.js:46 Mon Mar 28 2022 09:31:48 GMT+0100 (British Summer Time) Missing partition table ({“metadata”:{“size”:12222464,“name”:“StreamcorderHDHDMI-Recovery-134.img”,“hasMBR”:false,“extension”:“img”,“path”:”\\server1\transfer\AMPSoftware\Streamcorder\1.34\Firmware-Main\StreamCorderHDHDMI-Recovery-134\StreamcorderHDHDMI-Recovery-134.img"},“sample”:0.1,“applicationSessionUuid”:“4a733433-4f14-45fa-9afb-29f55f0ba235”,“flashingWorkflowUuid”:“36055f9a-ef58-4ca5-863b-17054ea8a71e”})
gui.js:46 Mon Mar 28 2022 09:31:48 GMT+0100 (British Summer Time) Select image ({“image”:{“size”:12222464,“name”:“StreamcorderHDHDMI-Recovery-134.img”,“hasMBR”:false,“extension”:“img”,“path”:“\\server1\transfer\AMPSoftware\Streamcorder\1.34\Firmware-Main\StreamCorderHDHDMI-Recovery-134\StreamcorderHDHDMI-Recovery-134.img”,“logo”:false,“blockMap”:false},“sample”:0.1,“applicationSessionUuid”:“4a733433-4f14-45fa-9afb-29f55f0ba235”,“flashingWorkflowUuid”:“36055f9a-ef58-4ca5-863b-17054ea8a71e”})
gui.js:46 Mon Mar 28 2022 09:31:53 GMT+0100 (British Summer Time) Flash ({“image”:{“size”:12222464,“name”:“StreamcorderHDHDMI-Recovery-134.img”,“hasMBR”:false,“extension”:“img”,“path”:“\\server1\transfer\AMPSoftware\Streamcorder\1.34\Firmware-Main\StreamCorderHDHDMI-Recovery-134\StreamcorderHDHDMI-Recovery-134.img”},“drives”:[{“size”:16172187648,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive1”,“error”:null,“isReadOnly”:false,“displayName”:“F:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:false,“device”:“\\.\PhysicalDrive1”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“F:\”}],“description”:“Generic- SD/MMC USB Device”,“isUAS”:false,“partitionTableType”:null}],“driveCount”:1,“uuid”:“10990183-af87-42a3-ad44-faf89bc382b7”,“status”:“started”,“flashInstanceUuid”:“10990183-af87-42a3-ad44-faf89bc382b7”,“sample”:0.1,“applicationSessionUuid”:“4a733433-4f14-45fa-9afb-29f55f0ba235”,“flashingWorkflowUuid”:“36055f9a-ef58-4ca5-863b-17054ea8a71e”})
gui.js:46 Elevating command: C:\Users\Admin\AppData\Local\Temp\26ZDwweoEftoYLfXXExMqtMd7tA\balenaEtcher.exe C:\Users\Admin\AppData\Local\Temp\26ZDwweoEftoYLfXXExMqtMd7tA\resources\app\generated\child-writer.js
gui.js:46 Terminating IPC server
gui.js:46 Flash results Object__proto
: Object
gui.js:46 Mon Mar 28 2022 09:31:53 GMT+0100 (British Summer Time) Write failed ({“image”:{“size”:12222464,“name”:“StreamcorderHDHDMI-Recovery-134.img”,“hasMBR”:false,“extension”:“img”,“path”:”\\server1\transfer\AMPSoftware\Streamcorder\1.34\Firmware-Main\StreamCorderHDHDMI-Recovery-134\StreamcorderHDHDMI-Recovery-134.img"},“drives”:[{“size”:16172187648,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive1”,“error”:null,“isReadOnly”:false,“displayName”:“F:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:false,“device”:“\\.\PhysicalDrive1”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“F:\”}],“description”:“Generic- SD/MMC USB Device”,“isUAS”:false,“partitionTableType”:null}],“driveCount”:1,“uuid”:“10990183-af87-42a3-ad44-faf89bc382b7”,“status”:“failed”,“flashInstanceUuid”:“10990183-af87-42a3-ad44-faf89bc382b7”,“error”:{},“sample”:0.1,“applicationSessionUuid”:“4a733433-4f14-45fa-9afb-29f55f0ba235”,“flashingWorkflowUuid”:“36055f9a-ef58-4ca5-863b-17054ea8a71e”})
gui.js:46 {“stack”:“Error: User did not grant permission.\n at file:///C%3A/Users/Admin/AppData/Local/Temp/26ZDwweoEftoYLfXXExMqtMd7tA/resources/app/generated/gui.js:46:702552\n at ChildProcess.exithandler (child_process.js:324:5)\n at ChildProcess.emit (events.js:315:20)\n at maybeClose (internal/child_process.js:1048:16)\n at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)”,“message”:“User did not grant permission.”,“image”:“StreamcorderHDHDMI-Recovery-134.img”}
gui.js:35 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
I am currently using 1.7.8 but have the same problem with 1.5.105
The “Error: User did not grant permission” occurs when a user did not grant elevated permissions to the application when it was requested (it’s required for accessing the mass storage device).
As for the other issues, since etcher uses electron, it is possible some of the .NET libraries are not available. You can try updating the .NET framework, but in general, such an old version of windows could have compatibility issues that we wouldn’t be able to address. You could also try using a much older version of etcher to see if it works: Releases · balena-io/etcher · GitHub
