Message from the UI:
Flash Failed.
Message from the notification area:
electron.app.balenaEtcher
Oops! Looks like the flash failed.
Something went wrong while writing ubuntu-24.04-desktop-amd64.iso to Kingston DataTraveler 3.0 USB Device(G:\,I:\).
Message from ctrl+shift+I
"name": "Error",
"description": "Kingston DataTraveler 3.0 USB Device",
"code": "EVALIDATION",
"device": "\\\\.\\PhysicalDrive6",
"message": "Checksum does not match for range [0, 6114656255]: \"~wTbW���\" != \"3W�$�wD\""
OS: Windows 10 Pro 22H2 19045.4291
Balena Version: balenaEtcher-Portable-1.18.11.exe
Note that:
- The flash drive is not defective.
- Ubuntu successfully install from the failed flash.
AS expected, windows failed to load the I drive, didn’t attempt to load the EFI partition, Windows is clean. Only suspect are Defender, Acronis, WSL2.
Knowing which part of the drive content was modified would help…
How can I see the differences between the flash drive and the iso ?
On which partition lies the problem?
Why doing a crc check if you know it will fail most of the time on Windows ?
Currently, windows attempt to load the drive (Why assign a letter?) and explorer show an error while the flash operation is not complete. That’s a bad design choice, and I suspect the reason for the problem. There are plenty of tools which manage to sidestep this issue.
The CRC should be computed before windows has a chance to access and modify the drive.
Better, we should be able to eject the drive before another process trash it.
