Hi! I am trying to flash a RaspberryOS ISO on my microSD card from Windows 10. My balenaEtcher version is 1.5.111.
When i click on “Flash!” I get this error:
{"stack":"Error: Command failed: cmd /c \"C:\\Users\\Ricky\\AppData\\Local\\Temp\\balena-etcher-electron--5704-qirraGKVVdTK-.cmd\"\r\n\"chcp\" non � riconosciuto come comando interno o esterno,\r\n un programma eseguibile o un file batch.\r\n\"cmd\" non � riconosciuto come comando interno o esterno,\r\n un programma eseguibile o un file batch.\r\n\n at file:///C%3A/Users/Ricky/AppData/Local/Programs/balena-etcher/resources/app/generated/gui.js:35961:33\n at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:61:3)","message":"Command failed: cmd /c \"C:\\Users\\Ricky\\AppData\\Local\\Temp\\balena-etcher-electron--5704-qirraGKVVdTK-.cmd\"\r\n\"chcp\" non � riconosciuto come comando interno o esterno,\r\n un programma eseguibile o un file batch.\r\n\"cmd\" non � riconosciuto come comando interno o esterno,\r\n un programma eseguibile o un file batch.\r\n","code":1,"image":"2020-08-20-raspios-buster-armhf-lite.img"}
All the parts in italian can be traslated as “not recognised as an internal or external command, a file that can be executed or a batch file”.
The popup error also says to check if the file is corrupted, but I already checked and the signature is ok.
I think this error is because of software or broken software files
do you reinstalled the application
if not
then try to do this please !!!
I already tried to reinstall the application. I also switched SD card and ISO, without getting any difference.
