I’m trying to clone my Windows 10 system 120GB SSD to a larger 1TB NVME M2 drive.
Unfortunately this error is preventing me from even starting the process.
And yes… I did run as administrator and made exclusions for balenaEtcher in WinDefender and even in Firewall just in case.
Here are the devtools
ab77
January 1, 2024, 11:56pm
2
These may help:
when i had seen developer tools console(Ctrl+shift+i) ,i get 3 errors
error1
{“stack”:“Error: The specified module could not be found.\r\n\\?\C:\Users\admin\AppData\Local\Programs\balena-etcher\resources\app\generated\modules\winusb-driver-generator\build\Release\Generator.node\n at process.func [as dlopen] (electron/js2c/asar.js:140:31)\n at Object.Module._extensions…node (internal/modules/cjs/loader.js:1034:18)\n at Object.func [as .node] (electron/js2c…
https://forums.balena.io/t/win-10-user-did-not-grant-permission/207435/56
opened 02:35AM - 27 Oct 21 UTC
closed 02:16AM - 18 Oct 22 UTC
- **Etcher version:1.5.122
- **Operating system and architecture: window 10
- … **Image flashed: 2020-12-13-qut-v35-raspbian-buster
- **Do you see any meaningful error information in the DevTools?
I cant flash the img to the sd card
<!-- You can open DevTools by pressing `Ctrl+Shift+I` (`Ctrl+Alt+I` for Etcher before v1.3.x), or `Cmd+Opt+I` if you're on macOS. --
