I downloaded and installed Etcher without any problems, in order to create a Linux boot SD drive. But when I tried to flash the .iso file, Etcher said:
Attention
Something went wrong. If it is a compressed image, please check that the archive is not corrupted.
User did not grant permission.
I checked the developer info:
Sun Jan 03 2021 04:16:47 GMT+0000 (Greenwich Mean Time) Write failed ({"image":{"size":1984790528,"name":"linuxmint-20-cinnamon-64bit.iso","hasMBR":true,"partitions":[{"offset":331776,"size":4063232,"type":239,"index":1}],"extension":"iso","path":"C:\\Users\\david\\Data - not synced\\Setup\\IT\\OS\\GNULinux\\linuxmint-20-cinnamon-64bit.iso"},"drives":[{"size":30752636928,"isVirtual":false,"enumerator":"USBSTOR","logicalBlockSize":512,"raw":"\\\\.\\PhysicalDrive1","error":null,"isReadOnly":false,"displayName":"D:\\","blockSize":512,"isSCSI":false,"isRemovable":true,"device":"\\\\.\\PhysicalDrive1","busVersion":"2.0","isSystem":false,"busType":"USB","isCard":false,"isUSB":true,"devicePath":null,"mountpoints":[{"path":"D:\\"}],"description":"SanDisk Ultra USB 3.0 USB Device","isUAS":false,"partitionTableType":"mbr"}],"driveCount":1,"uuid":"43c9139a-84ba-412c-9849-2c414a1f1662","status":"failed","flashInstanceUuid":"43c9139a-84ba-412c-9849-2c414a1f1662","error":{},"sample":0.1,"applicationSessionUuid":"32986797-e541-4b47-8fdb-ef56c5c8d3cf","flashingWorkflowUuid":"15db6602-1661-445e-a168-66b1127da288"})
gui.js:56886 {“stack”:“Error: User did not grant permission.\n at file:///C%3A/Users/david/AppData/Local/Programs/balena-etcher/resources/app/generated/gui.js:35942:35\n at ChildProcess.exithandler (child_process.js:311:5)\n at ChildProcess.emit (events.js:223:5)\n at maybeClose (internal/child_process.js:1021:16)\n at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)”,“message”:“User did not grant permission.”,“image”:“linuxmint-20-cinnamon-64bit.iso”}
I next whitelisted Etcher, but it made no difference.
Appreciate any suggestions!
Cheers.
