USB not formatable after use with balenaetcher
(Windows 10) USB not formatable after use with balenaetcher. Repeated with 3 (out of 3) USB drives (2 of which were new). Other USB drives work fine when not used with balenaetcher.
Diskpart clean doesn’t work.
chkdsk comes up with no errors.
does not format with disk management.
does not format from cmd. (with both fat32 and ntfs, as well as quick on/off)
sfc /scannow comes up with no errors.
write protection is disabled.
making volume active yields no results.
volume has been deleted and recreated.
file explorer>properties>tools>error checking>cannot access disk
driver updated
cmd detail disk results:
Philips USB Flash Drive USB Device
Disk ID: FEBE362F
Type : USB
Status : Online
Path : 0
Target : 0
LUN ID : 0
Location Path : UNAVAILABLE
Current Read-only State : No
Read-only : No
Boot Disk : No
Pagefile Disk : No
Hibernation File Disk : No
Crashdump Disk : No
Clustered Disk : No
Hello @potatoes welcome to the balena community and apologizes for the experience.
Did you try to follow the steps that we provide here? Etcher broke my USB stick … or did it?
Let us know if this helps!
yes I have. clean command could not access the usb
You need to run the command with admin access. Try the following:
  • Windows+X and make sure to open powershell(admin) and not just normal pwershell
Let us know if you any follow-up questions.
I tried this and it got worse. The disk was still “write protected” and the second time I tried your process, i got this:
Disk 1 is now the selected disk.
DISKPART> create partition primary
Virtual Disk Service error:
There is not enough usable space for this operation.
And that’s it–no other options. Any ideas?
Yes Balena Etcher just destroyed two 32 GB usb drives. I have seen so many posts on this. Etcher when will you fix?
Same issue. I have now lost the ability to access ANY usb thumb drive. This definitely did not happen before use belena. Having to re-install windows entire. Will not be recommending this at all going forward. Hope a fix happens soon…after several years. I did try the Etcher broke my USB stick … or did it?
it did not work. This seems like something that would prompt rolling back what ever version caused this.
I have similar issues every time I use BalenaEtcher. To solve it, I usually use Deskpart by selecting the disk and run these commands:
  1. clean
  2. create partition primary
  3. format fs=ntfs
You might find it took pretty long to finish, but it does the job.
