Can't access USB files!
I am using v1.5.107 with Windows 10, I tried to flash my large External Hard Drive with LMDE 4 and it said an error before it even started and then I can’t access my USB anymore! I looked at the article Etcher killed my USB stick but I either didn’t understand it or it didn’t help. I don’t know what to do!
Hi, In the article (https://www.balena.io/blog/did-etcher-break-my-usb-sd-card/) did you try the steps below “How to Recover a USB Drive or SD Card” -> “Using Windows” if so which steps did you try and what was the result?
Thank you so much! I just tried those steps and it worked! It didn’t work when I just tried to use diskpart to format it I had to use balenaEtcher to write an ISO file onto it so I can access it!
