- any:
Debian (via Crostini) ARM64:
I can’t install on my arm64 Samsung Chromebook plus. I need this working asap ( a few hours).
Upon sudo apt-get update, I get a
Failed to fetch https://deb.etcher.io/dists/1.5.17/etcher/binary-arm64/Packages 404 Not Found
I have tried replacing the stable field in
echo “deb https://deb.etcher.io stable etcher” | sudo tee /etc/apt/sources.list.d/balena-etcher.list
with ‘beta’, and ‘1.5.17.’ I checked the changelog, and arm64 support was in fact added in 1.4. Is there anything I can do?
Hi @Adonnen welcome to the forums!
Although we’ve added support for arm64 within the application, we don’t provide packages which is why you’re getting a 404 error. If you wanted to compile the application from source for arm64 it should work OK though.
