Do you guys ever plan on releasing Etcher for ARM64 support?
What’s the device you want it on? Are you trying to run it on a Mac? It does run on a mac…
There is currently an open issue for this feature request. To help us build the case internally, can you describe your setup that would benefit from native ARM64 releases?
I use a Acer Spin Chromebook 311 with a MediaTek chip (ARM).
Roger that, thank you. I can see how this would be important! It’s not a small undertaking to do right, but there is more and more talk about Etcher on ARM, so this will help the case.
