I downloaded the latest balenaEtcher app image, and deleted the old one. I double the new one to get started but nothing happens at all. I restarted the computer redownloaded the image but its not working. the app image was located in my home dir. but are there any locations where any “dependency” file so I can completely erase everything and start from scratch.
Hello, Could you tell me:
- What os and architecture are you using? (32/64).
- The name of the app image you downloaded?
Perhaps you are trying to run a 32bit image on a 64bit system?
There are a list of dependencies here, you might want to check that they are all availalbe (though they should be if you were running a previous version). You should not need to uninstall any dependencies.
https://github.com/balena-io/etcher/blob/master/docs/USER-DOCUMENTATION.md#runtime-gnulinux-dependencies
Debian 10 x64
Hello, on Debian you can use the deb packages: https://github.com/balena-io/etcher/releases/download/v1.5.89/balena-etcher-electron_1.5.89_amd64.deb
If you have time, can you please share the terminal output of running the AppImage: ./balenaEtcher-1.5.89-x64.AppImage ?
I downloaded the x64 but it didn’t do anything. then tried x86 to see if that would work but no bueno.
You mean the deb package ?
If you’re on a 64bit version of debian, you should use the 64bit package.
What happens if you run balena-etcher-electron in a terminal ?
Will do
I need to use wget to download the packages? I’m very good at using wget
Any http client should work
Your browser, wget, curl, anything should work
When I run balena-etcher-electron. It says command not found
You need to install the deb package after downloading it:
sudo dpkg -i balena-etcher-electron_1.5.89_amd64.deb
Then run it
You should be able to run apt-get install -f```` after running the dpkg``` command to install dependencies.
John
thank you all for the support
I have a question. Do you always have download .deb packages when after using wget to download something?
P.S. the image appeared thank you
for you support i’m going to test it out
Hi @Eboogie, nice to hear you made progress. Let us know if you encounter any issues.
Not sure if I understand the question. Your Linux OS Debian uses deb file format for distributing application packages. Ubuntu also used deb format. MacOS and Windows uses other file formats.
So I used wget to download balenaEtcher. But it still didnt work. Then I used dpkg -i to get the.deb packages. But should had the .deb packages get installed with wget.
Hi @Eboogie, wget just downloads the balenaEtcher binary but it doesn’t handle installation of dependencies like apt-get does. You will still need to install the .deb packages using dpkg -i before you are able to use Etcher.
The easiest way to set up Etcher is to follow the installation instructions for Debian on this link: https://github.com/balena-io/etcher#installers
I hope this helps you well.
Cheers,
Carlo
Thank you for the clarification
