ARM64 .deb succefully built
I had built successfully the deb file for ARM64.
I built for Debian Buster, but the source code was made for a gnome environment.
That’s mean need be installed with the option dpkg --force-all -i.
If the developer would it, send me a e-mail or a link please.
Regards
Hello I am not sure I understand what you need. Can you elaborate a bit more on what issue are you facing. What link are you referring to?
Thank you for reply mbalamat,
I had built and tested the deb file for ARM64.
I like to share it. How can I do it?
If you mean that you 'd like us to host the deb file you built, I am afraid that’s not possible because in general we don’t host files built by outside contributors.
Thank you anyway.
We will get in touch at github.
can you upload the image somewhere such as file.io or anywhere else so i can download it?
also, would you provide a simple tutorial on how you build that?
my email if needed:
mohammadhallajian@gmail.com
Regards
