I am running a distro called SolydXK version 2017 January.
It is based on Debian, but an earlier version dating from 2016.
PC is an HP dx2400 tower, with core 2 duo.
I have been able to run previous versions of etcher but the present one
1.5.115 will not run. It has permission to run as an executable.
Here is the response when I run it on the command line:
./balenaEtcher-1.5.115-x64.AppImage[9014:0127/162524.758288:FATAL:setuid_sandbox_host.cc(158)] The SUID sandbox helper binary was found, but is not configured correctly. Rather than run without sandboxing I’m aborting now. You need to make sure that /tmp/.mount_balenaeRl0yz/chrome-sandbox is owned by root and has mode 4755.
/tmp/.mount_balenaeRl0yz/balena-etcher-electron: line 10: 9014 Trace/breakpoint trap “{script_dir}"/balena-etcher-electron.bin "@”
