Hello. I have been able to use balena Etcher without problems with win10. Now that I upgrade to Windows 11, I can’t anymore.
As soon as I want to flash a usb stick, I got a win 11 error that says: Drive D: not found, that message apears about 5 times and then etcher shows: Something went wrong flasing you usb.
So far I have tried 3 isos: Zorin, Ubuntu and Kali linux. The final result of this is that the usb sticks became unusable, not even the balena instruccions for windows allowed me to fix those usb sticks and I end up throwing them out.
I just download the new portable version for etcher: 1.5.122 and tried again, but always the same thing happens: Windows says drive D can’t be found, even I use Etcher with admin priviledges.
Hello, Sorry to hear you are having problems with etcher on Windows 11. We haven’t encountered this problem before, and would like to know more about your specific OS version. Would you mind posting here the “Windows Specifications” section you see when you go to Settttings -> System -> About? Thank you.
Windows 11 was not working for me either. I did two things to get it working again.
Turned off “controlled folder access”. You can find this in your windows settings. If you are using a domain managed computer, you will have to turn it off via your local group policy. This got me to the point where Etcher was stuck on the starting screen.
You don’t even have to do that. It tells you which folders are protected (against ransomeware and other malware). Just move the file you want to use to a non protected folder. If you want something more universal, assign rights to the etcher programme.
