Hello team. No way to make Etcher work on my Windows 11 version (10.0.22621). No matter the image used or the SDCard type. I ran through forums and tried all actions I could find:
- run as admin
- disable folder control
- disable Defender
- use alternate folders, different USB ports and different SDCards
ScreenCap attached
I have succesfully run the job on Windows 10, although I had a “Failed” message at the end of the verification process, but the SDCard was OK.
Thanks for the help.
index.css:1 Failed to load resource: net::ERR_FILE_NOT_FOUND
gui.js:354 _____ _ _
| | | | | | ___ _ __
| || / | ’ \ / _ \ '|
_/ ____|| ||___||
Interested in joining the Etcher team?
Drop us a line at join+etcher@balena.io
Version = 1.18.11, Type = nsis
gui.js:37 Elevating command: C:\Users\jmloc\AppData\Local\Programs\balena-etcher\balenaEtcher.exe C:\Users\jmloc\AppData\Local\Programs\balena-etcher\resources\app\generated\child-writer.js
gui.js:37 Error: Error invoking remote method ‘disable-screensaver’: No handler registered for ‘disable-screensaver’
at o.invoke (node:electron/js2c/renderer_init:57:526)
(anonymous) @ gui.js:37
logException @ gui.js:37
(anonymous) @ gui.js:354
gui.js:35 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:37 Successfully connected to IPC server: etcher-server-3564, socket root C:\Users\jmloc\AppData\Local\Temp
gui.js:37 Image: P:\Documents\Astronomie\Projet Vaobis\StellarMateOS_1.7.9_64bit.img\StellarMateOS_1.7.9_64bit.img
gui.js:37 Devices: \.\PhysicalDrive3
gui.js:37 Auto blockmapping: true
gui.js:37 Decompress first: true
gui.js:37 Finish: 0
gui.js:37 Terminating IPC server
gui.js:37 Flash results {results: {…}, cancelled: false, skip: false}
gui.js:37 Error: Error invoking remote method ‘enable-screensaver’: No handler registered for ‘enable-screensaver’
