I have a problem with Etcher, I just have a white screen.
With vers. Etcher 1.4.9 win x64 & 1.4.6 on Win 10
Same for me. I’m on Windows 10 Pro x64. The cause is unknown. There is not pattern. It always seems to happen after shifting focus away from the app, though.
Hi, are you using the portable version or the installed one?
Also, what do you see in the console (Ctrl + Shift + i )?
I try with Etcher & the portable version.
When I open the console, I have : " DevTools was disconnected from teh page.
Once page is reloaded. DevTools will reconnect."
And nothing…
Same problem. UI blank after initial install. (tried both x64 and 32 bit versions with no change) Win 10 X64 version1.4.9 installed. Newbie trying to build Mint USB, but stuck. Thanks.
I also have the same issue. Downloaded the portable version link provided on Tails site. Ran and same blank window as OP.
Looks like I can scroll around and find links on the blank page by checking mouse pointer type while moving around, but this is unusable.
Windows 10 Pro x64 10.0.17134 Build 17134
Luckily Rufus portable works OK.
Dusty
Look like Etcher use component of base browser (maybe Internet Explorer), but you all not use/update IT. I use other OS and it work.
Hi, thanks for the reports.
Could you check if the issue is still reproducible with the latest balenaEtcher version?
At this moment, it’s 1.5.80
