Blank screen after installation on Windows 10
I have downloaded the balenaEtcher-Setup 1.5.56 for Windows 10.
I have install it with administrator rights.
By running it I only have a blank screen.
I have tried to re-download and re-install; always have a blank screen.
Is there any solution?
Can you try pressing Ctrl + Alt + I while the window is focused and send us any interesting logs that appear in there?
Could you also check whether the portable version has the same issue for you?
Ctrl + Alt + I —> nothing happens
Portable version has the same problems Blank screen and no logs by Ctrl + Alt + I
Oh sorry my bad, the shortcut for the dev tools is Ctrl + Shift + I.
With that open, you can then do Ctrl + R to reload so that we can get all the logs.
Can you also try to start etcher as a administrator, just to check whether this is a permissions related issue.
Also, have you been able to use an older version of etcher without facing this issue?
now I can get the DevTool but always get the same message by reloadig
I always run it as administrator.
I had an older version runnibg on another PC with Windows 10 and it worked perfectly.
It was last year and I don’t remember wich version it was
Hi, can you try reloading (ctrl + r in the DevTools) with the Console tab focused? There you can also enable logs persistence in the Console settings, which will keep logs even after the reload
Same issue here is the output from console from devtools
Version = 1.5.90, Type = nsis
    C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:448 Uncaught TypeError: Cannot read property 'path' of undefined
    at isSourceDrive (gui.js:1730)
    at Object.getDriveImageCompatibilityStatuses (gui.js:1822)
    at DriveCompatibilityWarning (gui.js:5060)
    at renderWithHooks (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:14803)
    at mountIndeterminateComponent (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:17482)
    at beginWork (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:18596)
    at HTMLUnknownElement.callCallback (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:188)
    at HTMLUnknownElement.wrapped (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:444)
    at Object.invokeGuardedCallbackDev (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:237)
    at invokeGuardedCallback (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:292)
    at beginWork$1 (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:23203)
    at performUnitOfWork (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:22154)
    at workLoopSync (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:22130)
    at performSyncWorkOnRoot (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:21756)
    at C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11089
    at unstable_runWithPriority (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\scheduler\cjs\scheduler.development.js:653)
    at runWithPriority$1 (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11039)
    at flushSyncCallbackQueueImpl (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11084)
    at flushSyncCallbackQueue (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11072)
    at scheduleUpdateOnFiber (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:21199)
    at Object.enqueueSetState (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:12639)
    at MainPage.Component.setState (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react\cjs\react.development.js:471)
    at gui.js:3898
    at changeHandler (gui.js:785)
    at Object.dispatch (C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\redux\lib\redux.js:228)
    at Object.setDrives (gui.js:2182)
    at setDrives (gui.js:3439)
    at Scanner.addDrive (gui.js:3451)
isSourceDrive @ gui.js:1730
getDriveImageCompatibilityStatuses @ gui.js:1822
DriveCompatibilityWarning @ gui.js:5060
renderWithHooks @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:14803
mountIndeterminateComponent @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:17482
beginWork @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:18596
callCallback @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:188
wrapped @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:444
invokeGuardedCallbackDev @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:237
invokeGuardedCallback @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:292
beginWork$1 @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:23203
performUnitOfWork @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:22154
workLoopSync @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:22130
performSyncWorkOnRoot @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:21756
(anonymous) @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11089
unstable_runWithPriority @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\scheduler\cjs\scheduler.development.js:653
runWithPriority$1 @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11039
flushSyncCallbackQueueImpl @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11084
flushSyncCallbackQueue @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11072
scheduleUpdateOnFiber @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:21199
enqueueSetState @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:12639
Component.setState @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react\cjs\react.development.js:471
(anonymous) @ gui.js:3898
changeHandler @ gui.js:785
dispatch @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\redux\lib\redux.js:228
setDrives @ gui.js:2182
setDrives @ gui.js:3439
addDrive @ gui.js:3451
async function (async)
addDrive @ gui.js:3446
emit @ events.js:203
onAttach @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\scanner.js:34
scan @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\adapters\block-device.js:94
scan @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\adapters\block-device.js:77
scanLoop @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\adapters\block-device.js:68
start @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\adapters\block-device.js:59
(anonymous) @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\scanner.js:59
(anonymous) @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\scanner.js:51
start @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\scanner.js:50
(anonymous) @ gui.js:3478
__webpack_require__ @ gui.js:21
(anonymous) @ gui.js:85
(anonymous) @ gui.js:88
C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 The above error occurred in the <DriveCompatibilityWarning> component:
    in DriveCompatibilityWarning (created by TargetSelector)
    in p (created by styled.div)
    in styled.div
    in Unknown (created by ForwardRef)
    in ForwardRef (created by Component)
    in Component (created by ForwardRef)
    in ForwardRef (created by ForwardRef)
    in ForwardRef (created by WithTheme(Component))
    in WithTheme(Component) (created by Styled(WithTheme(Component)))
    in Styled(WithTheme(Component)) (created by TargetSelector)
    in TargetSelector
    in div
    in div
    in Unknown (created by MainPage)
    in div (created by MainPage)
    in div (created by styled.div)
    in styled.div (created by ForwardRef)
    in ForwardRef (created by Box)
    in Box (created by Flex)
    in Flex (created by MainPage)
    in div (created by StyledGrommet)
    in StyledGrommet (created by Grommet)
    in Grommet (created by Styled(Grommet))
    in Styled(Grommet) (created by Provider)
    in BreakpointProvider (created by Provider)
    in Provider
    in MainPage
Consider adding an error boundary to your tree to customize error handling behavior.
Visit https://fb.me/react-error-boundaries to learn more about error boundaries.
console.<computed> @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58
logCapturedError @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:19527
logError @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:19564
update.callback @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:20708
callCallback @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:12490
commitUpdateQueue @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:12511
commitLifeCycles @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:19883
commitLayoutEffects @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:22803
commitRootImpl @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:22541
commitRoot @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:22381
finishSyncRender @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:21807
performSyncWorkOnRoot @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:21793
Show 2 more frames
C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 {"stack":"TypeError: Cannot read property 'path' of undefined\n    at isSourceDrive (file:///C:/Users/ms/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:1730:19)\n    at Object.getDriveImageCompatibilityStatuses (file:///C:/Users/ms/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:1822:9)\n    at DriveCompatibilityWarning (file:///C:/Users/ms/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:5060:55)\n    at renderWithHooks (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:14803:18)\n    at mountIndeterminateComponent (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:17482:13)\n    at beginWork (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:18596:16)\n    at HTMLUnknownElement.callCallback (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:188:14)\n    at HTMLUnknownElement.wrapped (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\raven-js\\dist\\raven.js:444:21)\n    at Object.invokeGuardedCallbackDev (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:237:16)\n    at invokeGuardedCallback (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:292:31)\n    at beginWork$1 (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:23203:7)\n    at performUnitOfWork (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:22154:12)\n    at workLoopSync (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:22130:22)\n    at performSyncWorkOnRoot (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:21756:9)\n    at C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:11089:24\n    at unstable_runWithPriority (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\scheduler\\cjs\\scheduler.development.js:653:12)\n    at runWithPriority$1 (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:11039:10)\n    at flushSyncCallbackQueueImpl (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:11084:7)\n    at flushSyncCallbackQueue (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:11072:3)\n    at scheduleUpdateOnFiber (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:21199:9)\n    at Object.enqueueSetState (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:12639:5)\n    at MainPage.Component.setState (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react\\cjs\\react.development.js:471:16)\n    at file:///C:/Users/ms/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:3898:18\n    at changeHandler (file:///C:/Users/ms/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:785:13)\n    at Object.dispatch (C:\\Users\\ms\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\redux\\lib\\redux.js:228:7)\n    at Object.setDrives (file:///C:/Users/ms/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:2182:19)\n    at setDrives (file:///C:/Users/ms/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:3439:21)\n    at Scanner.addDrive (file:///C:/Users/ms/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:3451:5)","message":"Cannot read property 'path' of undefined"}
logException @ C:\Users\ms\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\resin-corvus\src\resin-corvus.js:233
(anonymous) @ gui.js:3287
Same issue but I believe it is slightly different, here is the error from the dev console.
    at renderWithHooks (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:14803)
    at mountIndeterminateComponent (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:17482)
    at beginWork (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:18596)
    at HTMLUnknownElement.callCallback (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:188)
    at HTMLUnknownElement.wrapped (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:444)
    at Object.invokeGuardedCallbackDev (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:237)
    at invokeGuardedCallback (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:292)
    at beginWork$1 (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:23203)
    at performUnitOfWork (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:22154)
    at workLoopSync (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:22130)
    at performSyncWorkOnRoot (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:21756)
    at C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11089
    at unstable_runWithPriority (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\scheduler\cjs\scheduler.development.js:653)
    at runWithPriority$1 (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11039)
    at flushSyncCallbackQueueImpl (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11084)
    at flushSyncCallbackQueue (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11072)
    at scheduleUpdateOnFiber (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:21199)
    at Object.enqueueSetState (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:12639)
    at MainPage.Component.setState (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react\cjs\react.development.js:471)
    at gui.js:3898
    at Object.dispatch (C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\redux\lib\redux.js:228)
renderWithHooks @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:14803
mountIndeterminateComponent @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:17482
beginWork @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:18596
callCallback @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:188
wrapped @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:444
invokeGuardedCallbackDev @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:237
invokeGuardedCallback @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:292
beginWork$1 @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:23203
performUnitOfWork @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:22154
workLoopSync @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:22130
performSyncWorkOnRoot @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:21756
(anonymous) @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11089
unstable_runWithPriority @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\scheduler\cjs\scheduler.development.js:653
runWithPriority$1 @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11039
flushSyncCallbackQueueImpl @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11084
flushSyncCallbackQueue @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:11072
scheduleUpdateOnFiber @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:21199
enqueueSetState @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:12639
Component.setState @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react\cjs\react.development.js:471
dispatch @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\redux\lib\redux.js:228
onAttach @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\scanner.js:34
scan @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\adapters\block-device.js:94
scan @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\adapters\block-device.js:77
scanLoop @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\adapters\block-device.js:68
start @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\adapters\block-device.js:59
(anonymous) @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\scanner.js:59
(anonymous) @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\scanner.js:51
start @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\etcher-sdk\build\scanner\scanner.js:50
C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 The above error occurred in the <DriveCompatibilityWarning> component:
    in styled.div
    in TargetSelector
    in div
    in div
    in Provider
    in MainPage
console.<computed> @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58
logCapturedError @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:19527
logError @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:19564
update.callback @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:20708
callCallback @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:12490
commitUpdateQueue @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:12511
commitLifeCycles @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:19883
commitLayoutEffects @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:22803
commitRootImpl @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:22541
commitRoot @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:22381
finishSyncRender @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:21807
performSyncWorkOnRoot @ C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react-dom\cjs\react-dom.development.js:21793
Show 2 more frames
C:\Users\wcinv\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 {"stack":"TypeError: Cannot read property 'path' of undefined\n    at isSourceDrive (file:///C:/Users/wcinv/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:1730:19)\n    at Object.getDriveImageCompatibilityStatuses (file:///C:/Users/wcinv/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:1822:9)\n    at DriveCompatibilityWarning (file:///C:/Users/wcinv/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:5060:55)\n    at renderWithHooks (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:14803:18)\n    at mountIndeterminateComponent (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:17482:13)\n    at beginWork (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:18596:16)\n    at HTMLUnknownElement.callCallback (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:188:14)\n    at HTMLUnknownElement.wrapped (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\raven-js\\dist\\raven.js:444:21)\n    at Object.invokeGuardedCallbackDev (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:237:16)\n    at invokeGuardedCallback (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:292:31)\n    at beginWork$1 (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:23203:7)\n    at performUnitOfWork (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:22154:12)\n    at workLoopSync (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:22130:22)\n    at performSyncWorkOnRoot (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:21756:9)\n    at C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:11089:24\n    at unstable_runWithPriority (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\scheduler\\cjs\\scheduler.development.js:653:12)\n    at runWithPriority$1 (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:11039:10)\n    at flushSyncCallbackQueueImpl (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:11084:7)\n    at flushSyncCallbackQueue (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:11072:3)\n    at scheduleUpdateOnFiber (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:21199:9)\n    at Object.enqueueSetState (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react-dom\\cjs\\react-dom.development.js:12639:5)\n    at MainPage.Component.setState (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\react\\cjs\\react.development.js:471:16)\n    at file:///C:/Users/wcinv/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:3898:18\n    at changeHandler (file:///C:/Users/wcinv/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:785:13)\n    at Object.dispatch (C:\\Users\\wcinv\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\redux\\lib\\redux.js:228:7)\n    at Object.setDrives (file:///C:/Users/wcinv/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:2182:19)\n    at setDrives (file:///C:/Users/wcinv/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:3439:21)\n    at Scanner.addDrive (file:///C:/Users/wcinv/AppData/Local/Programs/balena-etcher/resources/app.asar/generated/gui.js:3451:5)","message":"Cannot read property 'path' of undefined"}
Hope we can figure this out soon.
Hi there – thanks very kindly for posting this. Can I ask you to file an issue and include that console output?
In the meantime, you may want to try temporarily running an earlier version of Etcher; you can download that from the releases page.
Thanks again,
Hugh
Hi ,
I ran in to the same issue and I think I found a workaround. It appears that the Etcher program does not like my SD card reader. The work around was that I turned on Etcher without the SD card reader attached and then I selected my disk image file (.img), next after selecting the image I get to the disk part of the wizard and of course it cannot find my disk, so hit “continue”, now plug in the SD card reader with the SD card and it should auto detect the card and select it for you.
The solution from billybob71a worked fine for me. Thank you!
The release 1.5.91 fixes the blank screen issue
We are happy to hear that everything works as intended. Thanks for bearing with us! :muscle:
