The install completes but clicking on the icon opens multiple processes but no program window. The portable version behaves the same way. Using Run as administrator with the portable version is the same.
I believe 1.5.56 was the last version that worked for me on Windows 10 1903. 1.5.56 portable creates a blank program window.
balenaEtcher-Portable-1.5.79.exe (md5sum 49cb69d9094159bc8fd799d7a64d55a2):
no window, task manager shows 3 Background processes labeled “balenaEtcher” and one Background process labeled “Flash OS images to SD cards and USB drives, safely and easily. (32-bit)” (I think this is the portable .exe).
When I started today, version 1.5.56 was installed on my system. I believe I had used it successfully some months ago but I could not find the icon to start it, so I downloaded 1.5.79, uninstalled 1.5.56, installed 1.5.79 and attempted to use it. When it failed, I downloaded it again, compared MD5sums, and also downloaded the portable version. Neither the installed version or the portable version worked so I started this thread. I also opened an issue (#3088) on the github site.
Thank you for making an issue, and I’m glad to hear that you got your image flashed. I checked out the issue you created, and if possible it would be good if you could share any console output, which you can see with ctrl+shift+I.
After 3 months without a definitive solution, I believe the answer is to use Win32DiskImager instead. I also understand that Rufus can be used as well, but I don’t need more than one solution, only one solution that works.
You can download older versions from here. The Etcher team just told me that there will be a new version available very soon, you might want to test it out to check if your problems went away.
We have a user reporting a few hours ago that a temporary workaround is to open Etcher before plugging in the SD Card. Can you check if that will work for you until the next version?
Indeed when my SDHC card is unplugged from my built-in card reader, the software is started as expected with blank screen. But when I plug the card after the starting, the screen becomes immediatly blank
I reported the problem with 1.5.79 (and noted that earlier versions also had issues). There have been 10 versions released since 1.5.79 and the problem still isn’t fixed so I believe you are overly optimistic about a fix in “a new version available very soon”.
As it is mentioned in the thread that you linked, the issue has been addressed in v1.5.91, can you please check to see if it works for you?
Best,
Odysseas
