Support for software
I would like to use Balena Sound to power my home sound system. I would also like to run another piece of software alongside BalenaOS on the same RPi.I would like to know if it is possible.
Here are two links to different projects but they all have the same output. So I can choose anything off the two
https://smartazanclock.com/setup/rpi
Here is a tutorial on how to merge 2 projects:
In your case, I think you could start from the balenaSound docker-compose.yml file and add the browser block to it. Check its README for configuring the LANCH_URL.
