How to run multiple projects on same device?
I am ignorant of Dockers and virtualization, so this question might be silly. I have a single RPi. I got to run a Pi-hole project based on BalenaOS on it. Now, I want to run another BalenaCloud application or project alongside on the same device. However, all the tutorials for projects spins up a new image to be flashed per application. Does it mean I can only run one application on a device? If not, how can I run two or more stuff on the same device?
Update: I did read the Multiple Containers doc page. Unfortunately I do not understand it at all.
Hi @mabhijithn,
You can find some binaries to play with here : https://github.com/balena-io-playground/multicontainer-metrics
You can begin with simple applications as Radarr or Jackett to begin :wink:
I found the guide on the Balena blog itself addressing the exact two projects I wanted to run simultaneously!
Yeah, that should be good info for your use case.
Let us know how that guide works for you!
It worked perfectly. Great guide… I was able to add another project (a google assistant) alongside it too.
