I just tried the Balena Sound tutorial for using my old HiFi via Bluetooth, because it seems really useful and fun.
Sadly it is not working for me.
My phone discovers and connects with balenaOS with no problem. I also can redirect the audio output in Spotify to balenaOs, the problem is that it does not sound in my speaker.
I have tried all the solutions I found over the internet, but anything worked.
I have a Raspberry Pi 4 with Balena OS 2.95.8, production 64bits, Supervisor version 13.0.
The solutions I have tried:
Removing vc4-kms-v3d overlay from the device configuration and rebooting.
Setting the env. var. DISABLE_MULTI_ROOM to 1 to disable multiroom
Restarted and rebooted the services and the device several times.
Using a SD class 10
Changing the SOUND_VOLUME to 100, just in case…
I would really appreciate any help or guidance, because I did not know about Balena Cloud, and I think I can use it more for all my projects if I can make it to work.
Just in case, I have enabled support access to the device for a week: 684f385214b265120fdf4e993a032434
Yeah, sure!
Thanks, I have granted support access again.
I want to play music from my phone’s spotify using balena sound wired to a speaker that does not have bluetooth.
Hi
I tried to access the device but it’s been a month since the last interaction ( sorry about that ) so it probably expired. Checking to see if you have managed to sort this out or if you’d like some more help. If you still need help could you re-enable access? And I’ll take a look
I created a new device, and flashed again the SD card.
But no, it does not work. I can pair both in Bluetooth and in spotify but it does not make any sound. I have tried in 2 different speakers. I am completely sure wires and speakers work properly.
I enable support access for a week.
Note, at the beggining the Balena did not appear in the bluetooth search of my phone, but It did appear in Spotify.
After connecting in Spotify I can see it in Bluetooth devices and I could connected.
