Sound out from Balena
is there any analog out of BalenaFin? There is no audio jack.
So I do not even have the PWM generated sound of the RPI?
If I overlooked an audio out. Can it be used in parallel to PWM or is it just feeding from the RPI?
Hi @Titanium
Thank you for your query. You are right that the BalenaFin does not have a 3.5mm audio output jack.
However, any DAC HAT for the Pi should also work on the Fin.
Kind regards
Alida
