Hi, I was following the tutorial on the website below, in order to use my raspberry pi zero w as a bluetooth receiver for my hifi. Whilst I am able to see the device as an option for bluetooth and airplay, there is no audio output. I think what makes this a bit more tricky is that the pi zero needs a DAC in order to connect a 3.5mm jack. In the tutorial it recommends adding a custom configuration: BALENA_HOST_CONFIG_dtoverlay with a value of hifiberry-dac. But I’m still not getting sound output. The DAC I am using is PCM5100A from: Audio DAC SHIM (Line-Out) — Pi Australia
Logs:
audio Waiting for sound supervisor to start at 172.17.0.1:80
audio Setting audio routing rules...
audio Routing 'balena-sound.input' to 'balena-sound.output'.
audio Routing 'balena-sound.output' to 'alsa_output.dac.stereo-fallback'.
audio
audio --- Audio ---
audio Starting audio service with settings:
audio - pulseaudio 15.0
audio - Pulse log level: NOTICE
audio - Default output: AUTO
audio - Default volume: 75%
audio
audio Detected audio cards:
audio 0 dac RPi-simple-snd_rpi_hifiberry_dac
audio
audio
sound-supervisor Error connecting to audio block - Retry failed: connect EHOSTUNREACH 192.168.1.129:4317
audio
audio --- Audio ---
audio
audio
audio
sound-supervisor Error connecting to audio block - Retry failed: connect ECONNREFUSED 192.168.1.129:4317
Starting service 'multiroom-client sha256:8b930bc65643d3b0a9611b2c4cb4ba5722d805988351b3ff73fbcfa5dc807c0d'
Starting service 'bluetooth sha256:fd7091daaf5cf30d1250e0a2e92c58d9231c27aa02a4f7fa175fb34cade986a2'
Starting service 'multiroom-server sha256:811c94828d68f403777863ae458813da12142973125805134ff5bfd1bf4f830a'
audio W: [pulseaudio] main.c: This program is not intended to be run as root (unless --system is specified).
audio W: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
audio W: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
sound-supervisor Connected to PulseAudio at 192.168.1.129:4317
sound-supervisor Server protocol version: 35
sound-supervisor Client protocol version: 33
audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 205.00 ms
Started service 'bluetooth sha256:fd7091daaf5cf30d1250e0a2e92c58d9231c27aa02a4f7fa175fb34cade986a2'
bluetooth Running balena base image entrypoint...
bluetooth --- Bluetooth ---
bluetooth Starting bluetooth service with settings:
bluetooth - Device name: balenaOS 917f
bluetooth - HCI interface: hci0
bluetooth - Pairing mode: SSP
bluetooth - PIN code: 0000
bluetooth Available HCI interfaces: hci0
bluetooth Resetting hci0
bluetooth Configuring selected interface: hci0
bluetooth hci0 Set Connectable complete, settings: powered connectable ssp br/edr le secure-conn
bluetooth hci0 Set Bondable complete, settings: powered connectable bondable ssp br/edr le secure-conn
bluetooth hci0 Set Discoverable complete, settings: powered connectable discoverable bondable ssp br/edr le secure-conn
bluetooth hci0 Set Secure Simple Pairing complete, settings: powered connectable discoverable bondable ssp br/edr le secure-conn
bluetooth Pairing mode set to 'Secure Simple Pairing Mode (SSPM)'. PIN code is NOT required.
bluetooth Bluetooth agent started!
bluetooth Checking for known bluetooth devices...
Started service 'multiroom-client sha256:8b930bc65643d3b0a9611b2c4cb4ba5722d805988351b3ff73fbcfa5dc807c0d'
multiroom-client
multiroom-client --- Multiroom ---
multiroom-client Starting multiroom service with settings:
multiroom-client - Mode: server
multiroom-client - Snapcast version: v0.25.0
multiroom-client Starting multi-room client...
multiroom-client - balenaSound mode: STANDALONE
multiroom-client - Target snapcast server: 192.168.1.129
multiroom-client Multi-room client disabled. Exiting...
Service exited 'multiroom-client sha256:8b930bc65643d3b0a9611b2c4cb4ba5722d805988351b3ff73fbcfa5dc807c0d'
Started service 'multiroom-server sha256:811c94828d68f403777863ae458813da12142973125805134ff5bfd1bf4f830a'
multiroom-server
multiroom-server --- Multiroom ---
multiroom-server Starting multiroom service with settings:
multiroom-server - Mode: server
multiroom-server - Snapcast version: v0.25.0
multiroom-server Multi-room server blacklisted for raspberry-pi. Exiting...
Service exited 'multiroom-server sha256:811c94828d68f403777863ae458813da12142973125805134ff5bfd1bf4f830a'
bluetooth AuthorizeService (/org/bluez/hci0/dev_F4_BE_EC_E6_CE_74, 0000110d-0000-1000-8000-00805f9b34fb)
audio W: [pulseaudio] module-loopback.c: Configured latency of 200.00 ms is smaller than minimum latency, using minimum instead
audio W: [pulseaudio] module-loopback.c: Cannot set requested source latency of 66.67 ms, adjusting to 250.00 ms
audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 284.25 ms
audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 210.00 ms
audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 215.00 ms
audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 220.00 ms
audio W: [pulseaudio] module-loopback.c: Cannot set requested source latency of 66.67 ms, adjusting to 68.54 ms
