Scroll to bottom of logs when displaying logs for a single service
Just a small suggestion for a usability improvement: on the device dashboard, when filtering multicontainer logs by service, the logs window always scrolls up to the top. However, when I click a button to view a service’s logs, it is most likely I want to see the latest logs and not some very old ones. Having to scroll all the way down a long log is annoying when I change filters a lot. It would therefore be better if the log window automatically scrolled to the bottom upon selecting a service.
Hi there, thanks a lot for your suggestion, it makes sense. I have already created an issue internally, and we will let you know once this is implemented. I am personally working on the dashboard, so if you have any other suggestions, I am all ears!
hey there,
This has been fixed and now when the filter is applied to the logswill scroll to the bottom to display the latest logs first
Thanks for reporting this!
Cheers!
Rahul
