I just wanted to report a small issue that has been cropping up for me recently.
When I go to troubleshoot a location I normally will open up a bunch of devices from that location in a bunch of different tabs. I do this so I can audit the logs and run terminal commands quickly on batches of devices.
However, on about every 1 in 2 devices I am getting “No logs yet” in the logs pannel.
This message will often resolve within 5-10 minutes, and sometimes faster, but it still slows me down and even worse is highly inconsistent between refreshes and different devices.
I also suspected that the log feed was also failing on me for a certain amount of time yesterday.
Thanks for your report. We’ve actually seen this internally as well, and we’re currently working on investigating and resolving this. We’ll let you know as soon as we have more information for you!
Log speeds are beyond 10x improved. A report I whipped the other day up to read all my devices logs and report a basic status used to take around 4-5 hours to run. It just ran in just over 2 minutes. Fantastic!
Hi, can you share with us support access to a device with slow logs? We’d like to investigate a bit more if possible, as we didn’t find anything suspicious on our end
Finding one device to share with you is hard because the problem normally resolves itself and then doesn’t come back (maybe I am warming up the cache?)
I haven’t had time today to confirm that this list is constant between runs, but I added code to time and record the time it takes to pull logs.
Thanks for all the info, we will investigate this further and let you know what we find. In the meantime, can you provide more details about the devices that have slow logs? Are they newly provisioned devices? Is it always the same devices that are slow, or it varies randomly? Any additional info would help a lot.
Hey, just to check the pastebin logs are numbered by latency right, not by order of querying? Just want to make sure it’s not a pattern where it gets slower after you’ve run a load of queries. Apart from that we’re planning to roll out some changes that should improve load generally but I also want to track down if there’s any remaining performance issues in the implementation itself, so knowing if there’s a way to trigger the slowness would be huge for me
Hey Thomas, it’s good to hear that this is not an issue anymore. We scaled up our redis instances, which is probably why you cannot reproduce it anymore. Do let us know if the issue appears again and you can reliably reproduce it.
