cloud gui log views options
would like a view = none
would like no “save as view” popup option when viewing a view ( i can only see a couple of log lines as it is)
Hi there,
if I understand correctly, here the problem is the display of filters inside the logs terminal, right? I understand that it can be a little invasive but here we have to show them since it show which filters are selected and then also give the possibility to remove them. Having said that we will certainly open a discussion on this point to see how we can improve the user experience. Maybe we can solve with an accordion to hide the selected filters or something similar. We have opened a GitHub issue for this and we will let you know as soon as we find a better solution. At the moment a suggestion that I can give you to solve this problem is to expand the logs terminal to get a wider view.
Thank you very much for the suggestion
