rosettaathome : which SVR ENV var do i use for my personal Cross-project ID
Hey, I believe ACCOUNT_KEY is the env var you are looking for. Check this section out: https://github.com/balenalabs/rosetta-at-home#customization
YES but you need to add the JOIN THE TEAM instructions (which i only just discovered on folding.io)
To join our team, visit the balena profile page and click ‘Join this team’
otherwise team balena will not get credit
the F@H process is DIFFERENT as you specify TEAM and USER on EACH node which is why i was trying to set up TEAM and USER on my balena nodes
neither my USERID or CROSSPROJECTID work as an ACCOUNT_KEY
BOINC-CLIENT just crashes
17.04.20 11:59:07 (+0100) boinc-client 17-Apr-2020 10:59:07 [Rosetta@home] Invalid or missing account key. To fix, remove and add this project .
and now there is no DELETE button for service envvars
https://dashboard.balena-cloud.com/devices/XXXX/service-envvars
HELP !
ah is see now
there is NO DELETE button on node level but if you go up to APP level there is a delete button
maybe need to make NODE GUI look more READONLY and not look identical to APP GUI
looking at the BOINC forum other users seem to having the same problem
https://boinc.bakerlab.org/rosetta/forum_thread.php?id=12856&postid=92995
FINALLY FOUND IT ! GET YOUR BOINC KEY FROM
https://boinc.bakerlab.org/rosetta/weak_auth.php
What do you do with that BOINC key in Balena to get rid of the message please?
get you BOINC key
click on your APP
click on SERVICE vars
add SERVER_ID insert BOINC key
service will reboot and start without errors
