Removal of BalenaEtcher via Windows 10 Add/Remove utility leaves program listed in installed programs.
I attempted to remove the program (latest version) using add/remove and received a prompt of: do I wish to remove Yes/No… Upon selected “yes” nothing occurs…
- how do I verify the program was removed ?
- hoe do I remove the program from the Add/Remove programs list…
Windows 10 Pro - build: 1903, 18362.329
Thank you
Sounds strange. Could you check if there are any leftover files by searching for balenaEtcher in the file explorer?
yes, finds application under C:\Users{user}\AppData\Local\Programs
Shortcuts, and some files marked with _1 and _0
when I click on the uninstall.exe directly, those files are now deleted… weirdness…
I don’t know what could’ve happened there. We’ll include the manual uninstallation in the troubleshooting though, thank you for reporting and taking the time to look into it!
