I get an error that pops up:
Windows cannot find ‘C:\Users\username\AppData\Local\Programs\balena-etcher\UninstallbalenaEtcher.exe’
I had 2 versions installed and tried to clean things up so I only have 1. I can install 1.5.64 and it seems just fine. I tried to install 1.5.59 again and it gets about a third of the way and it just stops and doesn’t appear to use any cpu or make any progress.
If I have both 1.5.64 and 1.5.59 installed and I click on uninstall on the 1.5.59 one it uninstalls the 1.5.64 version.
I decided to try some things. I installed 1.5.64 and then I installed 1.5.59 and it worked and when I did that it removed the 1.5.64 version and then I was able to uninstall the 1.5.59 version. So then I was left with all versions removed. I then was able to install 1.5.64 again and I am good.
I am going to leave this, maybe it will help someone else.
