Hi! I followed your Guide: https://www.balena.io/blog/turn-your-old-speakers-or-hi-fi-into-bluetooth-receivers-using-only-a-raspberry-pi/ and it seems to be working mostly… Spotify works and everything but it doesn’t show up as a bluetooth device. All Services including Bluetooth are marked as running and restarting the bluetooth agent doesn’t seem to help. My Raspberry Pi is a RPi 3 B+. Here is a copy of my Bluetooth log: 18.12.20 13:45:07 (+0100) bluetooth Running balena base image entrypoint…
18.12.20 13:45:07 (+0100) bluetooth — Bluetooth —
18.12.20 13:45:07 (+0100) bluetooth Starting bluetooth service with settings:
18.12.20 13:45:07 (+0100) bluetooth - Device name: balenaOS 7c79
18.12.20 13:45:07 (+0100) bluetooth - HCI interface: hci0
18.12.20 13:45:07 (+0100) bluetooth - Pairing mode: SSP
18.12.20 13:45:07 (+0100) bluetooth - PIN code: 0000
18.12.20 13:45:07 (+0100) bluetooth Available HCI interfaces: hci0
18.12.20 13:45:07 (+0100) bluetooth Resetting hci0
18.12.20 13:45:07 (+0100) bluetooth Configuring selected interface: hci0
18.12.20 13:45:07 (+0100) bluetooth hci0 Set Connectable complete, settings: powered connectable ssp br/edr le secure-conn
18.12.20 13:45:07 (+0100) bluetooth hci0 Set Bondable complete, settings: powered connectable bondable ssp br/edr le secure-conn
18.12.20 13:45:07 (+0100) bluetooth hci0 Set Discoverable complete, settings: powered connectable discoverable bondable ssp br/edr le secure-conn
18.12.20 13:45:07 (+0100) bluetooth hci0 Set Secure Simple Pairing complete, settings: powered connectable discoverable bondable ssp br/edr le secure-conn
18.12.20 13:45:07 (+0100) bluetooth Pairing mode set to ‘Secure Simple Pairing Mode (SSPM)’. PIN code is NOT required.
18.12.20 13:45:09 (+0100) bluetooth Bluetooth agent started!
18.12.20 13:53:00 (+0100) spotify [2020-12-18T12:53:00Z INFO librespot_playback::player] Loading <What’s Up Danger (with Black Caviar)> with Spotify URI spotify:track:5zsHmE2gO3RefVsPyw2e3T
18.12.20 13:53:00 (+0100) spotify [2020-12-18T12:53:00Z INFO librespot_playback::player] <What’s Up Danger (with Black Caviar)> (222306 ms) loaded
18.12.20 13:53:01 (+0100) sound-supervisor Playback started, announcing 192.168.0.23 as multi-room master!
18.12.20 13:53:33 (+0100) Killing service ‘bluetooth sha256:d248a2c53b76f795627ec99d23e909a913f5f94e85856c03f4a3cdb170586f91’
18.12.20 13:53:46 (+0100) Service exited ‘bluetooth sha256:d248a2c53b76f795627ec99d23e909a913f5f94e85856c03f4a3cdb170586f91’
18.12.20 13:53:46 (+0100) Killed service ‘bluetooth sha256:d248a2c53b76f795627ec99d23e909a913f5f94e85856c03f4a3cdb170586f91’
18.12.20 13:53:47 (+0100) Installing service ‘bluetooth sha256:d248a2c53b76f795627ec99d23e909a913f5f94e85856c03f4a3cdb170586f91’
18.12.20 13:53:47 (+0100) Installed service ‘bluetooth sha256:d248a2c53b76f795627ec99d23e909a913f5f94e85856c03f4a3cdb170586f91’
18.12.20 13:53:47 (+0100) Starting service ‘bluetooth sha256:d248a2c53b76f795627ec99d23e909a913f5f94e85856c03f4a3cdb170586f91’
18.12.20 13:53:49 (+0100) Started service ‘bluetooth sha256:d248a2c53b76f795627ec99d23e909a913f5f94e85856c03f4a3cdb170586f91’
18.12.20 13:53:48 (+0100) bluetooth Running balena base image entrypoint…
18.12.20 13:53:49 (+0100) bluetooth — Bluetooth —
18.12.20 13:53:49 (+0100) bluetooth Starting bluetooth service with settings:
18.12.20 13:53:49 (+0100) bluetooth - Device name: balenaOS 7c79
18.12.20 13:53:49 (+0100) bluetooth - HCI interface: hci0
18.12.20 13:53:49 (+0100) bluetooth - Pairing mode: SSP
18.12.20 13:53:49 (+0100) bluetooth - PIN code: 0000
18.12.20 13:53:49 (+0100) bluetooth Available HCI interfaces: hci0
18.12.20 13:53:49 (+0100) bluetooth Resetting hci0
18.12.20 13:53:49 (+0100) bluetooth Configuring selected interface: hci0
18.12.20 13:53:49 (+0100) bluetooth hci0 Set Connectable complete, settings: powered connectable ssp br/edr le secure-conn
18.12.20 13:53:49 (+0100) bluetooth hci0 Set Bondable complete, settings: powered connectable bondable ssp br/edr le secure-conn
18.12.20 13:53:49 (+0100) bluetooth hci0 Set Discoverable complete, settings: powered connectable discoverable bondable ssp br/edr le secure-conn
18.12.20 13:53:49 (+0100) bluetooth hci0 Set Secure Simple Pairing complete, settings: powered connectable discoverable bondable ssp br/edr le secure-conn
18.12.20 13:53:49 (+0100) bluetooth Pairing mode set to ‘Secure Simple Pairing Mode (SSPM)’. PIN code is NOT required.
18.12.20 13:53:50 (+0100) bluetooth Bluetooth agent started!
I hope you can help me…
