BalenaSound not showing up as a device for Spotify connect
After installing BalenaSound on my Raspberry Pi B+, I could see my device show up as a connect option in Spotify, after rebooting due to it not connecting it no longer shows up as a connection option. Nothing shows up under the BalenaCloud terminal when I am trying to view the logs for Spotify.
OS: balenaOS 2.46.1+rev1 Production
Hi @JTech_Defiant,
Thanks for writing. We’re looking into this and will get back to you.
John
Hi [@JTech_Defiant,
Spotify Connect only works with Spotify Premium accounts (due to the use of the librespot library). Can you confirm you’re using a paid Spotify account?
John
@Jtech_Defiant,
I did some investigation and had a similar issue getting Spotify to see the balenaSound device. There’s an existing bug related to alsa sound that may be helpful: https://github.com/balenalabs/balena-sound/issues/106. I found that by adding RUN install_packages alsa-utils in the ./spotify/Dockerfile.template effectively reinstalled Alsa and solved the issue. Can you check that and see if you get a similar result?
John
I have had a similar issue. I am running a single Pi 3B. OS version 2.47 .0 rev 1., and the latest version of balenaSound, v2.23, last commit 01-May-2020.
Installation went smoothly, and the unicorn appeared.
I don’t want multi room, so I set the variable which disables that. My Pi 3B definitely has a Wi-Fi connection, otherwise how would I see it as a device in my balenaCloud dashboard? I also changed the name using the DEVICE_NAME variable so that all services have the same name change. I don’t use Airplay, so I have no idea if that is working or not.
Result is that Bluetooth works, but for Spotify the device stubbornly will not appear in the device list on any Spotify application. Other Spotify devices do appear.
I have tried stopping all other services to isolate Spotify (restarting Spotify after stopping the other services). Yes, I do have a Spotify Premium account. I have also tried adding ‘RUN install_packages alsa-utils’ to the Spotify docker template file, then rebuilding as suggested in the forums, suggesting that somehow a fresh Alsa install over the top seems to fix an underlying bug. No change.
I have even started again totally from scratch, following the process to the letter, but the result is the same. I even thought my router had gone bad, so restarted that as well.
I used balenaSound last year, it installed first time and ran beautifully. This time, I am stuck!
Here are the logs:
Spotify alone:
08.05.20 12:54:50 (+0100) spotify [2020-05-08T11:54:50Z INFO librespot] librespot (raspotify v0.14.0) 3672214 (2020-01-30). Built on 2020-02-16. Build ID: 7pZDdYUK
08.05.20 12:56:35 (+0100) spotify [2020-05-08T11:56:35Z INFO librespot] librespot (raspotify v0.14.0) 3672214 (2020-01-30). Built on 2020-02-16. Build ID: 7pZDdYUK
Everything:
08.05.20 11:55:15 (+0100) Killed service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 11:55:15 (+0100) Killing service ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 11:55:17 (+0100) Killed service ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 11:55:17 (+0100) Service exited ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 11:55:17 (+0100) Killing service ‘airplay sha256:e167b38d8b9d04306603d9ce1c1be0dda6e95d46b5949da29c89dd2593b19b29’
08.05.20 11:55:29 (+0100) Killed service ‘airplay sha256:e167b38d8b9d04306603d9ce1c1be0dda6e95d46b5949da29c89dd2593b19b29’
08.05.20 11:55:29 (+0100) Service exited ‘airplay sha256:e167b38d8b9d04306603d9ce1c1be0dda6e95d46b5949da29c89dd2593b19b29’
08.05.20 11:55:29 (+0100) Killing service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 11:55:29 (+0100) Service is already stopped, removing container ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 11:55:29 (+0100) Killed service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 11:55:29 (+0100) Killing service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 11:55:29 (+0100) Service is already stopped, removing container ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 11:55:29 (+0100) Killed service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 11:55:29 (+0100) Killing service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 11:55:29 (+0100) Service is already stopped, removing container ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 11:55:29 (+0100) Killed service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 11:55:29 (+0100) Rebooting
08.05.20 11:56:42 (+0100) Supervisor starting
08.05.20 11:56:17 (+0100) airplay Device is discoverable as “balenaSound Airplay be34”
08.05.20 11:56:44 (+0100) Starting service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 11:56:44 (+0100) Starting service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 11:56:44 (+0100) Starting service ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 11:56:44 (+0100) Starting service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 11:56:44 (+0100) Starting service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 11:56:49 (+0100) Started service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 11:56:50 (+0100) Started service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 11:56:50 (+0100) snapcast-client Multi-room audio is disabled, not starting snapclient.
08.05.20 11:56:51 (+0100) Started service ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 11:56:51 (+0100) Started service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 11:56:51 (+0100) fleet-supervisor Multi-room audio is disabled, not starting fleet supervisor.
08.05.20 11:56:51 (+0100) Service exited ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 11:56:53 (+0100) Service exited ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 11:56:54 (+0100) Service exited ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 11:56:54 (+0100) Started service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 11:56:54 (+0100) snapcast-server Multi-room audio is disabled, not starting snapserver.
08.05.20 11:56:55 (+0100) bluetooth-audio Setting output volume to 75%
08.05.20 11:56:55 (+0100) bluetooth-audio Connection notify volume is 75%
08.05.20 11:56:55 (+0100) bluetooth-audio amixer: Unable to find simple control ‘Digital’,0
08.05.20 11:56:55 (+0100) bluetooth-audio Restarting bluetooth service
08.05.20 11:56:58 (+0100) Service exited ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 11:56:59 (+0100) bluetooth-audio rm: cannot remove ‘/root/.asoundrc’: No such file or directory
08.05.20 11:57:00 (+0100) bluetooth-audio Bluetooth agent registered
08.05.20 11:57:01 (+0100) bluetooth-audio Starting bluetooth agent in Secure Simple Pairing Mode (SSPM) - No PIN code provided or invalid
08.05.20 11:57:03 (+0100) bluetooth-audio Attempting to reconnect to previous bluetooth device: D4:38:9C:E5:D9:17
08.05.20 11:57:05 (+0100) bluetooth-audio Device is discoverable as “vita_audio_r1”
08.05.20 12:47:34 (+0100) Killing service ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 12:47:35 (+0100) Killing service ‘airplay sha256:e167b38d8b9d04306603d9ce1c1be0dda6e95d46b5949da29c89dd2593b19b29’
08.05.20 12:47:35 (+0100) Killing service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:47:35 (+0100) Service is already stopped, removing container ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:47:35 (+0100) Killing service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:47:35 (+0100) Service is already stopped, removing container ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:47:35 (+0100) Killing service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:47:35 (+0100) Service is already stopped, removing container ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:47:35 (+0100) Killing service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:47:35 (+0100) Service is already stopped, removing container ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:47:35 (+0100) Killed service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:47:35 (+0100) Killed service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:47:35 (+0100) Killed service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:47:35 (+0100) Killed service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:47:37 (+0100) Service exited ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 12:47:37 (+0100) Killed service ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 12:47:37 (+0100) Installing service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:47:37 (+0100) Installing service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:47:37 (+0100) Installing service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:47:37 (+0100) Installing service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:47:40 (+0100) Installed service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:47:40 (+0100) Starting service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:47:40 (+0100) Installed service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:47:40 (+0100) Starting service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:47:40 (+0100) Installed service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:47:40 (+0100) Starting service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:47:42 (+0100) Installed service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:47:42 (+0100) Starting service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:47:45 (+0100) Started service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:47:45 (+0100) Started service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:47:45 (+0100) snapcast-client Multi-room audio is disabled, not starting snapclient.
08.05.20 12:47:46 (+0100) Started service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:47:45 (+0100) fleet-supervisor Multi-room audio is disabled, not starting fleet supervisor.
08.05.20 12:47:48 (+0100) Started service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:47:49 (+0100) Service exited ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:47:49 (+0100) Service exited ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:47:49 (+0100) Service exited ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:47:49 (+0100) Service exited ‘airplay sha256:e167b38d8b9d04306603d9ce1c1be0dda6e95d46b5949da29c89dd2593b19b29’
08.05.20 12:47:49 (+0100) Killed service ‘airplay sha256:e167b38d8b9d04306603d9ce1c1be0dda6e95d46b5949da29c89dd2593b19b29’
08.05.20 12:47:51 (+0100) Service exited ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:47:47 (+0100) snapcast-server Multi-room audio is disabled, not starting snapserver.
08.05.20 12:47:51 (+0100) Installing service ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 12:47:51 (+0100) Killing service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:47:51 (+0100) Service is already stopped, removing container ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:47:51 (+0100) Killing service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:47:51 (+0100) Service is already stopped, removing container ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:47:51 (+0100) Killing service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:47:51 (+0100) Service is already stopped, removing container ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:47:51 (+0100) Killing service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:47:51 (+0100) Service is already stopped, removing container ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:47:51 (+0100) Killed service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:47:51 (+0100) Killed service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:47:51 (+0100) Killed service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:47:51 (+0100) Killed service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:47:52 (+0100) Installed service ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 12:47:52 (+0100) Starting service ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 12:47:55 (+0100) Started service ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 12:47:55 (+0100) bluetooth-audio Setting output volume to 75%
08.05.20 12:47:55 (+0100) bluetooth-audio Connection notify volume is 75%
08.05.20 12:47:55 (+0100) bluetooth-audio amixer: Unable to find simple control ‘Digital’,0
08.05.20 12:47:55 (+0100) bluetooth-audio Restarting bluetooth service
08.05.20 12:47:55 (+0100) Installing service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:47:55 (+0100) Installing service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:47:55 (+0100) Installing service ‘airplay sha256:e167b38d8b9d04306603d9ce1c1be0dda6e95d46b5949da29c89dd2593b19b29’
08.05.20 12:47:56 (+0100) Installing service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:47:56 (+0100) Installing service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:47:57 (+0100) Installed service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:47:57 (+0100) Starting service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:47:58 (+0100) Installed service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:47:58 (+0100) Starting service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:47:59 (+0100) bluetooth-audio Bluetooth agent registered
08.05.20 12:48:00 (+0100) Installed service ‘airplay sha256:e167b38d8b9d04306603d9ce1c1be0dda6e95d46b5949da29c89dd2593b19b29’
08.05.20 12:48:00 (+0100) Starting service ‘airplay sha256:e167b38d8b9d04306603d9ce1c1be0dda6e95d46b5949da29c89dd2593b19b29’
08.05.20 12:48:00 (+0100) Installed service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:48:00 (+0100) Starting service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:48:01 (+0100) Installed service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:48:01 (+0100) Starting service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:48:00 (+0100) bluetooth-audio Starting bluetooth agent in Secure Simple Pairing Mode (SSPM) - No PIN code provided or invalid
08.05.20 12:48:02 (+0100) Started service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:48:02 (+0100) Started service ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:48:02 (+0100) snapcast-client Multi-room audio is disabled, not starting snapclient.
08.05.20 12:48:02 (+0100) bluetooth-audio Attempting to reconnect to previous bluetooth device: D4:38:9C:E5:D9:17
08.05.20 12:48:05 (+0100) Started service ‘airplay sha256:e167b38d8b9d04306603d9ce1c1be0dda6e95d46b5949da29c89dd2593b19b29’
08.05.20 12:48:05 (+0100) Service exited ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:48:03 (+0100) airplay Device is discoverable as “vita_audio_r1”
08.05.20 12:48:05 (+0100) Service exited ‘snapcast-client sha256:0a29caafa2fd7dee33ca548011f9ddc116ad78c4417ace728507e94715178951’
08.05.20 12:48:04 (+0100) bluetooth-audio Device is discoverable as “vita_audio_r1”
08.05.20 12:48:05 (+0100) Started service ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:48:04 (+0100) fleet-supervisor Multi-room audio is disabled, not starting fleet supervisor.
08.05.20 12:48:07 (+0100) Service exited ‘fleet-supervisor sha256:cf6f4079256006fc5dc51cd0d88005b59b6e186186cf93a052cb1e1eb09fe2fe’
08.05.20 12:48:07 (+0100) Started service ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:48:07 (+0100) snapcast-server Multi-room audio is disabled, not starting snapserver.
08.05.20 12:48:09 (+0100) Service exited ‘snapcast-server sha256:3deb8de5a3eb5ee7f47f6c402c12ad5ee46f67ace34e550c3009731e0b2a80f0’
08.05.20 12:48:39 (+0100) Starting service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:48:41 (+0100) Started service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:48:41 (+0100) Restarting service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:48:42 (+0100) Service exited ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:54:33 (+0100) Downloading image ‘registry2.balena-cloud.com/v2/42d4e80f12a8bf49fa4d78b7193f3255@sha256:fd87d0134984f1c85841f1f67f062d06458755609183569712ed96740492b0c7
08.05.20 12:54:44 (+0100) Downloaded image ‘registry2.balena-cloud.com/v2/42d4e80f12a8bf49fa4d78b7193f3255@sha256:fd87d0134984f1c85841f1f67f062d06458755609183569712ed96740492b0c7
08.05.20 12:54:45 (+0100) Killing service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:54:45 (+0100) Service is already stopped, removing container ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:54:45 (+0100) Killed service ‘spotify sha256:c3a88c8e0761d40ea1cd2608f82d39d8f517686fa904f9e886ce2c7fa3b278be’
08.05.20 12:54:46 (+0100) Deleting image ‘registry2.balena-cloud.com/v2/2db48f38cf7fe439f52a35c2fdcb3acd@sha256:75d8affa12cb9089f0bd60169232770bc4602ee7174e3a8e90268a997ed4a15f
08.05.20 12:54:46 (+0100) Deleted image ‘registry2.balena-cloud.com/v2/2db48f38cf7fe439f52a35c2fdcb3acd@sha256:75d8affa12cb9089f0bd60169232770bc4602ee7174e3a8e90268a997ed4a15f
08.05.20 12:54:47 (+0100) Installing service ‘spotify sha256:b3f960917799b75fcff5cf95e42c62a11a772d712ee8597021445b77898adeee’
08.05.20 12:54:48 (+0100) Installed service ‘spotify sha256:b3f960917799b75fcff5cf95e42c62a11a772d712ee8597021445b77898adeee’
08.05.20 12:54:48 (+0100) Starting service ‘spotify sha256:b3f960917799b75fcff5cf95e42c62a11a772d712ee8597021445b77898adeee’
08.05.20 12:54:50 (+0100) Started service ‘spotify sha256:b3f960917799b75fcff5cf95e42c62a11a772d712ee8597021445b77898adeee’
08.05.20 12:56:00 (+0100) Killing service ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 12:56:02 (+0100) Killed service ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 12:56:02 (+0100) Service exited ‘bluetooth-audio sha256:bef20377bbd5e4fc2cf104ae1884f5907de61adbbd41c45ed801a72412f415ec’
08.05.20 12:56:05 (+0100) Killing service ‘airplay sha256:e167b38d8b9d04306603d9ce1c1be0dda6e95d46b5949da29c89dd2593b19b29’
08.05.20 12:56:17 (+0100) Killed service ‘airplay sha256:e167b38d8b9d04306603d9ce1c1be0dda6e95d46b5949da29c89dd2593b19b29’
08.05.20 12:56:17 (+0100) Service exited ‘airplay sha256:e167b38d8b9d04306603d9ce1c1be0dda6e95d46b5949da29c89dd2593b19b29’
08.05.20 12:56:20 (+0100) Killing service ‘spotify sha256:b3f960917799b75fcff5cf95e42c62a11a772d712ee8597021445b77898adeee’
08.05.20 12:56:32 (+0100) Service exited ‘spotify sha256:b3f960917799b75fcff5cf95e42c62a11a772d712ee8597021445b77898adeee’
08.05.20 12:56:32 (+0100) Killed service ‘spotify sha256:b3f960917799b75fcff5cf95e42c62a11a772d712ee8597021445b77898adeee’
08.05.20 12:56:32 (+0100) Installing service ‘spotify sha256:b3f960917799b75fcff5cf95e42c62a11a772d712ee8597021445b77898adeee’
08.05.20 12:56:33 (+0100) Installed service ‘spotify sha256:b3f960917799b75fcff5cf95e42c62a11a772d712ee8597021445b77898adeee’
08.05.20 12:56:33 (+0100) Starting service ‘spotify sha256:b3f960917799b75fcff5cf95e42c62a11a772d712ee8597021445b77898adeee’
08.05.20 12:56:35 (+0100) Started service ‘spotify sha256:b3f960917799b75fcff5cf95e42c62a11a772d712ee8597021445b77898adeee’
I’d really like to get this going in it’s standard, intended form. It’s a great project, but I need a bit of help.
Hi, just checking if anybody solved this? I have similar issue on balenaOS 2.65.0+rev1
Same here, no Spotify target on fresh install on RPi3B
