Hi!
I have a problem with my rasp. When I flash the image, i put it on my rasp.
It connect with Balena cloud and i seet it, but when it starts to update, it stops at 70/80% and I stopped seeing it online, and on my local network.
Any solution?
Hi @juangarcon are you still experiencing this behavior? Without any other info, it’s a bit difficult to diagnose it. What happens when you unplug/plug the device? Can you try flashing it again? You could also try to flash it with a different SD card and see if that helps.
