I am not familiar with this forum but I wanted to let you know that when I tried to install Zorin it broke my flash drive. It was a SanDisk I tried everything command prompt, format everything and nothing worked except Power Iso free trial…
You go to tools then clean the drive -it will format at the end then will function again. I hope this helps someone who’s watching and has this issue.
Hi, were you using balenaEtcher to flash Zorin? If so what OS were you using with Etcher?
