Pi Zero 2 W with Boss Mini DAC
I’m trying to use a newly purchased Boss Mini DAC with a Raspberry Pi Zero 2 W but Balena Sound seems to be unable to connect to the DAC;
 audio  --- Audio ---
 audio  Starting audio service with settings:
 audio  - pulseaudio 15.0
 audio  - Pulse log level: NOTICE
 audio  - Default output: AUTO
 audio  - Default volume: 75%
 audio
 audio  Detected audio cards:
 audio  ---nosoundcards---
However on a Raspberry Pi 4 it’s recognised fine;
 audio  --- Audio ---
 audio
 audio  0 bcm2835-hdmi0 bcm2835_hdmi-bcm2835HDMI1
 audio  1 bcm2835-jack bcm2835_headpho-bcm2835Headphones
 audio  2 BossDAC BossDAC-BossDAC
I tried on an old Pi Zero W and had the same result as the Pi Zero 2 W - no sound card detected. Is there a difference in how the images are built? Are there any additional properties I need to set in order for Balena Sound to recognise the DAC on a Pi Zero?
