Hi, thanx, still no luck.
I’ve check that aplay -L showed a device:
snd_rpi_hifiberry_dac and I’ve set the CUSTOM CONFIGURATION VARIABLES
to:
BALENA_HOST_CONFIG_dtoverlay not defined snd_rpi_hifiberry_dac
But now, after several reboots:
/usr/src# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default
Playback/recording through the PulseAudio sound server
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
hw:CARD=bcm2835-alsa,DEV=0
bcm2835 ALSA, bcm2835 ALSA
Direct hardware device without any conversions
hw:CARD=bcm2835-alsa,DEV=1
bcm2835 ALSA, bcm2835 IEC958/HDMI
hw:CARD=bcm2835-alsa,DEV=2
bcm2835 ALSA, bcm2835 IEC958/HDMI1
plughw:CARD=bcm2835-alsa,DEV=0
Hardware device with all software conversions
plughw:CARD=bcm2835-alsa,DEV=1
plughw:CARD=bcm2835-alsa,DEV=2
sysdefault:CARD=bcm2835-alsa
Default Audio Device
dmix:CARD=bcm2835-alsa,DEV=0
Direct sample mixing device
dmix:CARD=bcm2835-alsa,DEV=1
dmix:CARD=bcm2835-alsa,DEV=2
usbstream:CARD=bcm2835-alsa
bcm2835 ALSA
USB Stream Output
Could not find the DAC, the Pimoroni is not soldered it 's connected by a plastic piece with pins so I’m kinda lost here, because several other times the DAC was listed.
