Hi, Raspberry Pi Zero 2 does not detect sound cards.
I connected the supported DAC. Raspberry Pi Zero and 4 correctly detects it immediately after installation, even without additional configuration.
RP Zero 2 does not work despite having “BALENA_HOST_CONFIG_dtoverlay” and “AUDIO_OUTPUT - DAC” set.
Audio log message below
audio Detected audio cards:
audio —nosoundcards—
Hi, @mishaps, we haven’t thoroughly tested balenaSound with the Pi Zero 2. Can you ssh into the audio service and run a few commands? That might help troubleshoot.
In the audio service run:
aplay -L
aplay -l
cat /proc/asound/cards
In the hostOS:
Hi, thanks for the answer. There were some smooth running issues on Pi Zero, so I opted for Pi Zero 2, although you are right this version is not marked as supported
Audio service
bash-5.1# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
bash-5.1# aplay -l
aplay: device_list:274: no soundcards found…
bash-5.1# cat /proc/asound/cards
— no soundcards —
hostOS
root@balena:~# cat /proc/asound/cards
— no soundcards —
I tried with these DACs
