On a Jetson TX2 devkit with a Resin OS 2.19.0+rev1my services can’t be installed:
Failed to install service 'main sha256:97dc4d31f5f18f1e328dd91525250a2b60865d1f222f44239a7580078ceb1f51' due to '(HTTP code 500) server error - --storage-optis supported only for overlay over xfs with 'pquota' mount option '
We started this a while back and didn’t realise that you had already added the Orbitty, Spacely boards. So I just redid the changes for the Aetina board, following the the steps done for the Orbitty and Spacely boards. This time based on 2.24 rev1.
I get a tegra186-quill-p3310-1000-c03-00-base.dtb in /boot, but that one does not have the expected md5. In the image I get 32abe8069f0542375109d58fb533823b, while the file from Aetina has a6921fee2045f63bd001efcdc869c05f:
Hi. Indeed. And the kernel already has the sources for this. You can find them in your build dir, under tmp/work-shared/n510-tx2/kernel-source/nvidia/platform/t18x/quill/kernel-dts
So the problem seems to be that the build system is using the sources for built-in one instead of the prebuilt one.
Is there a problem if you use the one that comes with the kernel?
Great, thank you.
As a workaround in the meantime, is there a way to manually copy the .dtb to the boot folder?
Either once it is running, before the .img is built or injecting it into the img?
Easiest would be to use an USB stick and copy it on a running system in the /mnt/boot/ directory, overwriting the existing one.
You can also modify the produced .img but it required more steps and if it’s just for a test on one machine, I recommend using the USB approach
So for the USB approach do I understand correctly:
Put the .dtb that I want on the USB stick, attach that to the device, ssh in (website or local mode) and copy it to /mnt/boot?
I just checked, the device has no .dtb in /mnt/boot.
I’ve managed to get the .dtb on /mnt/boot. There was not .dtb so nothing was overwritten.
I restarted the device, but the dtb in /boot is still the old one.
The last one is the desired one. On /boot I can’t write. @floion Overwriting the /mnt/sysroot/active/balena/overlay2/3ad9531a18920dd95dc09b52edf860d9c9386c62e70e76308f81db0eb6c16e87/diff/boot/tegra186-quill-p3310-1000-c03-00-base.dtb also changed /boot. That seems to have worked.
After reboot the md5sum in /boot also matched what I expected.
@floion Yes, I could copy the files on. However, still no luck on the USB3.
I was wondering how the .dtb in /boot interacts with the .dtb.encrypt files in /opt/tegra-binaries.
There is a tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt in /opt/tegra-binaries
Since I copied a different tegra186-quill-p3310-1000-c03-00-base.dtb this ...sigheader.dtb.encrypt doesn’t match. Could that interfere with loading the .dtb correctly?
I’m afraid the manufacturer won’t give the sources… They only provide a zip with the dtb, a .common file and a kernel image.
As I mentioned before the kernel image is from unmodified L4T sources though.
Hooked up a TTL232-USB converter and getting the serial console:
When I try to boot with the FDT command in /mnt/extlinux/extlinux.conf it tries to retrieve the .dtb file and then complains about 'Unable to read file ‘/boot/…’
Found resin image on mmc 0
Loading resinOS_uEnv.txt from mmc device 0 partition 0xC
reading resinOS_uEnv.txt
** Unable to read file resinOS_uEnv.txt **
Unknown command 'setexpr' - try 'help'
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:c...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
232 bytes read in 12 ms (18.6 KiB/s)
Boot Options
1: primary Image
Enter choice: 1: primary Image
Retrieving file: /Image
reading /Image
23760016 bytes read in 596 ms (38 MiB/s)
append: console=ttyS0,115200 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1t
Retrieving file: /boot/tegra186-quill-p3310-1000-c03-00-base.dtb
reading /boot/tegra186-quill-p3310-1000-c03-00-base.dtb
** Unable to read file /boot/tegra186-quill-p3310-1000-c03-00-base.dtb **
Skipping primary for failure retrieving fdt
SCRIPT FAILED: continuing...
Scanning MMC and USB devices 0 1 2
reading resin-image-flasher
** Unable to read file resin-image-flasher **
MMC: no card present
** Bad device mmc 1 **
MMC Device 2 not found
** Bad device mmc 2 **
** Bad device usb 0 **
** Bad device usb 1 **
** Bad device usb 2 **
