It seems that the DTB files are in fact encrypted or at least signed and therefore with R28.2 one cannot make use of the DTB / FTB statement in the extlinux.conf: https://devtalk.nvidia.com/default/topic/1035622/jetson-tx2/in-system-update-of-dtb-in-r28-2/post/5266971/#5266971
When I plainly replace the .dtb in /boot the device does boot, but U-Boot complains about a bad CRC and then falls back to a default environment, loading a flattened device tree blob:
U-Boot 2016.07 (Oct 27 2018 - 10:30:38 +0000)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
Scanning MMC and USB devices 0 1 2
reading resin-image-flasher
** Unable to read file resin-image-flasher **
reading resin-image
24 bytes read in 8 ms (2.9 KiB/s)
MMC: no card present
** Bad device mmc 1 **
MMC Device 2 not found
** Bad device mmc 2 **
** Bad device usb 0 **
** Bad device usb 1 **
** Bad device usb 2 **
Found resin image on mmc 0
Loading resinOS_uEnv.txt from mmc device 0 partition 0xC
reading resinOS_uEnv.txt
** Unable to read file resinOS_uEnv.txt **
Unknown command 'setexpr' - try 'help'
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:c...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
174 bytes read in 13 ms (12.7 KiB/s)
Boot Options
1: primary Image
Enter choice: 1: primary Image
Retrieving file: /Image
reading /Image
23760016 bytes read in 596 ms (38 MiB/s)
append: console=ttyS0,115200 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1t
## Flattened Device Tree blob at 92000000
Booting using the fdt blob at 0x92000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000092000000, end 0000000092049330
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-l4t-r28.2+g174510d (oe-user@oe-host) (gcc version 6.3.0 (GCC) ) #2 SMP PREEMPT Sun Oct 28 09:30:00 UTC 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
