I want to get resinOS working with the CTI Orbitty. I saw that a custom board based of the Orbitty is being supported under SKX2. Is that just matter for me to add another machine and swap with their provided dtb?
Hi, our team member working on the TX2 is on leave today but he will look at this when he comes back.
That was not the intent behind the skx2, but you can use it for that purpose. Replace this (https://github.com/resin-os/resin-jetson-tx2/blob/master/layers/meta-resin-jetson/recipes-kernel/linux/linux-tegra/tegra186-tx2-cti-ASG916.dtb) with their specific dtb and you should be able to use the TX2 with the CTI Orbitty.
Kind regards,
Theodor
Thanks @telphan it worked
Would it be better for me to add a new machine and do a PR? Is that something you would be open to?
Yes, we are always open to PRs.
