Hi, I am having no luck getting Balena Sound up and running. The log is stuck at “Creating Network” and I don’t see the list of running services. I do know that the services aren’t running, though, because it is not available in Spotify. Am I doing something wrong? Any guidance would be greatly appreciated. Thanks!
Hello, it looks like the balenaSound application has not yet been pushed to your device. Did you use the “Deploy with balena” button to start the installation or a different method?
Hi, I ended up removing it from the Pi Zero, but had deployed it through Balena Cloud. I will have a Pi 4 to try it on and will post again once it has been deployed to the Pi. Thank you!
