No Device Online BalenaCloud
Hi, my raspberry pi zero is not coming online as a device in my balena dashboard. I flashed the SD card and it is plugged into power + ethernet. How can I get my device to show up?
Hello @ablack
Welcome to the balena Forums.
Did you create a fleet on the balena dashboard and download the OS image from the ‘Add device’ section?
If you downloaded an image from balenaOS - Run Docker containers on embedded IoT devices instead it will be ‘unmanaged’ and will need to be configured before it will show up under your fleet on the dashboard.
Regards - Mark
Hello @ablack
Please let us know if you are still having problems with this.
Thanks - Mark
