Hello - I’m trying to install a new Resin application on a Nuc-based Logic Supply ML100. I have used this Nuc in the past with Resin OS 2.2.0+rev1 (prod) and was able to install successfully. With my new app however, when I boot off the USB, I get stuck on the screen attached.
The most relevant message looks like the overlapping partitions one. If you plug the USB stick into a PC and run fdisk on it does the partition table look OK?
I tried installing a new app on the Nuc and it seemed to hang up on the Resin screen while installing (so I rebooted). Ever since then, I’ve been stuck on this “overlapping partition” issue
