Issue with Bluetooth and Spotify
Hi there!
I installed balenaCloud on my Rasberry Pi3. I used to have problems with Dockerfile.template because I had to change the ‘d’ to capital ‘D’. But after doing that it uploaded nicely. Now I want to connect my device to the speakers. When I use Spotify, the device doesn’t show up as a ‘Spotify Device’, it’s invisible. I have Spotify premium account so this shouldn’t be an issue.
The other problem is the Bluetooth. My phone finds the balenaSound and it connects but there is no sound when I play music or video. Also after a few minutes it disappears as an option from the Bluetooth list, I mean I can’t see it on the Bluetooth list on my phone, but it still connected somehow.
What should I do? What is the problem?
I would use Spotify so I would like solve that problem first.
Hi @Nutella02,
If you want to use Spotify Connect over the internet, you’ll need to provide your Spotify credentials. To enable Spotify login you can add your username/e-mail and password, which are set with two environment variables: SPOTIFY_LOGIN and SPOTIFY_PASSWORD. It sounds like you configured that, but can you confirm?
For the output issue, it could be related to the volume settings. This can be set with the SYSTEM_OUTPUT_VOLUME environment variable. The balenaSound docs page also has some other troubleshooting tips. Also, balenaSound has a Deploy to balena option, which will provide base configurations and load the GitHub content automatically. You can also add environmental variables during the application-creation. https://dashboard.balena-cloud.com/deploy?repoUrl=https://github.com/balenalabs/balena-sound
John
Is there an option to give my Spotify credentials to balenaSound?
Yes, in the balenaCloud dashboard, click on the balenaCloud application, then click on “Device variables”. Create two new variables SPOTIFY_LOGIN (your email address usually) and SPOTIFY_PASSWORD. I’ve just done a fresh deployment on an RPi 3 and notice that the bluetoothXXX device is not staying visible in Spotify. I’ll check with our engineers on this.
Also, if you’re using just a single device, create another device environment variable called DISABLE_MULTI_ROOM and set the value to 1.
John
This sound good. I’m a beginner at this can you explain me this step-by-step? I mean, I found the ‘Add Device Variables’ option but I don’t know what should I write in the boxes. Can you show me this configuration step-by-step?
Hi, here is the link with the detailed description on how to enter variables: https://www.balena.io/docs/learn/manage/serv-vars/
Here is the GitHub issue that my colleague commented on when he tested the Spotify integration and it did not work for him: https://github.com/balenalabs/balena-sound/issues/224
Zahari
Hi there! It looks like I solved the problem. Now I’m able to see the device on ‘Spotify Connect’. The problem is that there is no sound when I play the song. On Spotify I can see that the song is on but I can’t hear it. I’m using a HiFi berry AMP 2 and HiFi berry digi. What is the issue? What should I do?
Have you configured your device to use the Hifiberry DAC? See here:
Phil
