Hello, looks like something is causing Etcher to crash on startup. Would you mind trying to open it again and open up the developer tools from the blank window (should be Ctrl + Shift + I on windows)? Once that is open you should be able to click on Console which will contain all the application logs. Could you copy all that and share it with us in this thread?
Thank you
Thanks, what version of Etcher are you using, and would you be able to confirm if you can run any other electron app?
Im using 1.5.81
Can you provide the version of Electron you have installed? The current supported versions (according to Electron) are 8.1.x, 7.1.x and 6.1.x.
John
Hi I had the same problem on win7, solved using "compatibility program " winxp
bye
Hi, I’m having the same exact problem with version 1.7.7 on Windows 7 SP1 32-bit. I just downloaded Etcher a few minutes ago.
Here’s what my console is showing:
Failed to load resource: net::ERR_FILE_NOT_FOUND
electron/js2c/asar_bundle.js:5 Uncaught Error: \\?\C:\Users\Sammy\AppData\Local\Programs\balena-etcher\resources\app\generated\modules\@ronomon\direct-io\binding.node is not a valid Win32 application.
at process.func [as dlopen] (electron/js2c/asar_bundle.js:5)
at Object.Module._extensions..node (internal/modules/cjs/loader.js:1138)
at Object.func [as .node] (electron/js2c/asar_bundle.js:5)
at Module.load (internal/modules/cjs/loader.js:935)
at Module._load (internal/modules/cjs/loader.js:776)
at Function.f._load (electron/js2c/asar_bundle.js:5)
at Function.o._load (electron/js2c/renderer_init.js:33)
at Module.require (internal/modules/cjs/loader.js:959)
at require (internal/modules/cjs/helpers.js:88)
at Object.<anonymous> (gui.js:1)
Also, opening it with a compatibity layer set to either Windows XP Service Pack 2 or 3 didn’t work.
Hi @samuelitooooo welcome to the forums!
Are you using the portable or installer version of etcher?
Installer.
Same problem as him… How i can fix this.
Same problem as above… windows 7 64
