already destroyed 3 USB drives by trying to re-format them after having them used with balena Images. I could not reactivate them, allthough I tried all options as described in the “how to recover broken usb drive” topic.
Now I have a new 64GB USB drive flashed with Balena Etcher, which works.
But I would like to bring it back to default state and format it with FAT32 - without destroying it.
Hi @mab . I think the answer will depend on what OS your laptop is running, but there should be a number of tools to format usb drives to FAT32. I think one that comes up often for windows is Rufus: https://rufus.ie/
You should very easily be able to format a USB stick to FAT32 on macOS (OSX) by using the built in Disk Utility tool (Applications->Utilities->Disk Utility).
Once loaded, insert the USB stick you want to format and then select it in the list of ‘External’ media in the left hand panel (it will be called ‘flash-boot’ if it previously had a balenaOS image flashed to it). Once selected, go to the ‘Erase’ icon at the top of the Disk Utility pane, and then select MS-DOS (FAT) as the disk type. Give it a name, if you require. Finally, select ‘Erase’.
I still got the same troubles with USB flash drives, that has once been used by balena.
All of them are not recoverable and abviously damaged…
It is not possible to format them, it is not possbile to erase them completely.
Believe me, I’m working in the IT…
I tried diskpart.exe and other diskmanagers.
The USB drives that are “infected” by Balena are not getting healthy again, if you want to use them for usual Data storage.
Only the Balena Image is working, but never try to bring the Flashdrive back to a usual one again…
First of all, apologizes for the experience. Having said that, did you try to recover your USB flash drives following our instructions here? → Etcher broke my USB stick … or did it?
I’m not sure if your read my actual posting or maybe my old postings before…
For sure I tried everything with diskpart.exe and other operating systems.
as I described: Using the Etcher works fine! Using the image works fine.
But if you want to go back to a usual data storage device, it does not work and destroys the flash disk.
Hello @mpous
no, what I say is, that once you try to format it, you get an error and will never be able to format it correctly again.
And if you try to delete the partitions and create new ones, it will only let you create a partition, but it won’t let you format it.
In no operating system, not windows, not linux debian, not osx.
Hi I was having the same problem and the solution that worked for me is the following that you can try. I am using windows system and any windows system shoud produce the same results.
I will try to explain it step by step so that anyone should be able to follow along and obtain the solution to this annoying but solvable problem.
Right click windows and select: Command Prompt (Admin)
On the terminal write: diskpart
Once DiskPart opens
Type: list disk
It will list the disks.
At this point you can plug the USB into the pc and again type: list disk
Now you should be able to correctly identify your USB as you can compare with the previous list. For this example I will say Disk 1 is the USB
Make sure you have the correct USB selected and if you are not sure you can just unplug it and type list disk again until you are sure it is appearing. WARNING. if you select the wrong disk it can erase or destroy your pc.
Type: select disk 1 Terminal will confirm with message: Disk 1 is now the selected disk. Or whatever disk number applies to your USB.
Type: clean If terminal won’t clean and gives an error message. You need to do the following.
Type: convert gpt
Terminal will confirm: successfully converted the selected disk to GPT format.
Again Type: clean
If at this point you don’t get the message:
Succeeded in cleaning the disk.
Again type: convert gpt
It may not work the first time so if needed you may have to repeat the clean, convert gpt, clean command until you get the message, succeeded in cleaning the disk
which should appear if you followed the instructions.
**Then if all is well ** you should get the confimation: succeeded in creating the specified partition. and succeeded in cleaning the disk
Now Type: create partition primary
Now you can open a documents folder and select: This PC
Locate the USB you have been working on and right click and select Format
You can use th FAT32 (Default) or one of the other options if you require it.
When you are ready you can select Quick format and Start.
Your USB should now be ready to use again for whatever you want as it has successfully been cleaned and reformatted.
I’ve had the same issue and was stuck with a USB drive that I thought was done. I tried all this with no success. The error was persistent. Then I found a video that did much the same but via the command prompt available in the windows recovery at startup. From the recovery menu’s command prompt it took the ‘clean’ command without the need to ‘convert gpt’ and was successful first time. See here; https://www.youtube.com/watch?v=vKiJZ7k0yqs
